I have a pair of GL-B1300 routers. #1 is connected via cable to my modem, #2 is in repeater mode. I work connected to #2.
The connection drops regularly for a period of 30s-1m and then suddenly recovers. This only seems to happen on Router #2. I’ve updated both routers to firmware 3.212. I’ve even replaced router #2, and still have the same issue. Logs collected following the most recent example below. Any ideas?
Router 1 Logs
Wed Aug 24 12:47:47 2022 daemon.notice netifd: wwan (10013): udhcpc: sending discover
Wed Aug 24 12:47:47 2022 daemon.notice netifd: wwan (10013): udhcpc: sending select for 192.168.8.167
Wed Aug 24 12:47:47 2022 daemon.notice netifd: wwan (10013): udhcpc: lease of 192.168.8.167 obtained, lease time 43200
Wed Aug 24 12:47:47 2022 kern.err kernel: [78576.088638] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc8048000
Wed Aug 24 12:47:47 2022 kern.err kernel: [78576.108656] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc9eb8000
Wed Aug 24 12:47:47 2022 daemon.warn dnsmasq[2729]: no servers found in /tmp/resolv.conf.auto, will retry
Wed Aug 24 12:47:47 2022 daemon.notice netifd: Interface 'wwan' is now up
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: reading /tmp/resolv.conf.auto
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using local addresses only for domain test
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using local addresses only for domain onion
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using local addresses only for domain localhost
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using local addresses only for domain invalid
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using local addresses only for domain bind
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using local addresses only for domain lan
Wed Aug 24 12:47:47 2022 daemon.info dnsmasq[2729]: using nameserver 192.168.8.1#53
Wed Aug 24 12:47:47 2022 kern.warn kernel: [78576.610333] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_disable: swbmiss disabled by SCANNER curmask 0x3
Wed Aug 24 12:47:48 2022 kern.warn kernel: [78576.918806] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_enable: swbmiss enabled by SCANNER curmask 0x2
Wed Aug 24 12:47:48 2022 kern.err kernel: [78577.396889] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:47:48 2022 kern.err kernel: [78577.397029] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 0(ms)
Wed Aug 24 12:47:48 2022 kern.err kernel: [78577.418457] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:47:48 2022 kern.err kernel: [78577.418774] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 1(ms)
Wed Aug 24 12:47:49 2022 user.info mwan3rtmon[2786]: Detect rtchange event.
Wed Aug 24 12:47:50 2022 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta0)
Wed Aug 24 12:47:57 2022 kern.err kernel: [78586.108545] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc8048000
Wed Aug 24 12:47:57 2022 kern.err kernel: [78586.128524] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc9eb8000
Wed Aug 24 12:47:57 2022 kern.warn kernel: [78586.650479] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_disable: swbmiss disabled by SCANNER curmask 0x3
Wed Aug 24 12:47:58 2022 kern.warn kernel: [78586.957755] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_enable: swbmiss enabled by SCANNER curmask 0x2
Wed Aug 24 12:47:58 2022 kern.err kernel: [78587.419373] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:47:58 2022 kern.err kernel: [78587.419488] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 1(ms)
Wed Aug 24 12:47:58 2022 kern.err kernel: [78587.458314] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:47:58 2022 kern.err kernel: [78587.458448] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 0(ms)
Wed Aug 24 12:48:07 2022 kern.err kernel: [78596.128434] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc8048000
Wed Aug 24 12:48:07 2022 kern.err kernel: [78596.148426] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc9eb8000
Wed Aug 24 12:48:07 2022 kern.warn kernel: [78596.650075] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_disable: swbmiss disabled by SCANNER curmask 0x3
Wed Aug 24 12:48:08 2022 kern.warn kernel: [78596.957367] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_enable: swbmiss enabled by SCANNER curmask 0x2
Wed Aug 24 12:48:08 2022 kern.err kernel: [78597.436571] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:48:08 2022 kern.err kernel: [78597.436707] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 0(ms)
Wed Aug 24 12:48:08 2022 kern.err kernel: [78597.458482] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:48:08 2022 kern.err kernel: [78597.458600] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 0(ms)
Wed Aug 24 12:48:17 2022 kern.err kernel: [78606.148354] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc8048000
Wed Aug 24 12:48:17 2022 kern.err kernel: [78606.168354] wlan: [0:I:ANY] ieee80211_autoselect_infra_bss_channel: 3995: ACS started: vap:0xc9eb8000
Wed Aug 24 12:48:17 2022 kern.warn kernel: [78606.669831] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_disable: swbmiss disabled by SCANNER curmask 0x3
Wed Aug 24 12:48:18 2022 kern.warn kernel: [78606.977250] [UNSPECIFIED] vap-1(wlan-sta0):mlme_sta_swbmiss_timer_enable: swbmiss enabled by SCANNER curmask 0x2
Wed Aug 24 12:48:18 2022 kern.err kernel: [78607.456600] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:48:18 2022 kern.err kernel: [78607.456716] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 0(ms)
Wed Aug 24 12:48:18 2022 kern.err kernel: [78607.477867] wlan: [1493:E:ANY] ol_ath_get_chan_grade_info: 5621: RF characterization entries is empty
Wed Aug 24 12:48:18 2022 kern.err kernel: [78607.478009] wlan: [1493:I:ANY] ieee80211_acs_scan_evhandler: 3732: lock held duration: 0(ms)
Router 2 Logs
