Has anyone been able to setup a guest network on a Gl-B1300 mesh network?
I fallowed the steps on the OpenWRT Wiki but I had problems getting an ipv4 addresses and that was before I even connected 2 of the routers. So any advice would be great.
I can start to connect to the new network but I can’t get an ip address
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-Ping'
option src 'wan'
option proto 'icmp'
option icmp_type 'echo-request'
option target 'DROP'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option src_ip 'fe80::/10'
option src_port '547'
option dest_ip 'fe80::/10'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
list icmp_type 'bad-header'
option limit '1000/sec'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
config rule
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule 'glservice_rule'
option name 'glservice'
option dest_port '83'
option proto 'tcp udp'
option src 'wan'
option enabled '0'
config rule
option dest_port '53'
option name 'guest-DNS'
option src 'guest'
config rule
option src 'wan'
option proto 'udp'
option dest 'guest'
option name 'guest-DHCP-renew'
config rule
option src 'wan'
option proto 'udp'
option name 'Guest-DHCPv6'
option dest 'guest'
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option disabled '0'
config zone
option name 'lan'
option forward 'ACCEPT'
option network 'lan'
config zone
option name 'wan'
option masq '1'
option mtu_fix '1'
option input 'DROP'
option forward 'DROP'
option network 'wan wan6'
config include
config include 'miniupnpd'
option type 'script'
option path '/usr/share/miniupnpd/firewall.include'
option family 'any'
option reload '1'
config include 'qcanssecm'
option path '/etc/firewall.d/qca-nss-ecm'
option family 'any'
option reload '0'
config include 'shadowsocks'
option path '/var/etc/shadowsocks.include'
option reload '1'
config zone
option name 'guest'
option input 'REJECT'
option network 'guest'
config forwarding
option dest 'wan'
option src 'guest'
config forwarding
option dest 'wan'
option src 'lan'
PS after fallowing the steps on the OpenWRT wiki and double checking them and it still didn’t work I then compared the settings for the new gust network to the setting for the already existing networks and made some changes which is what you’re seeing here.
Thank you so far it looks like it’s working I’ll need to test a few things later. I’m not sure if it’s working on both routers but I’ll test that out and post later.
I was wrong it’s not working. I’m still only able to connect using DHCPv6 on my computer and I can’t connect at all on my phone (Which makes sense because I don’t believe that Android supports DHCPv6). I’ve double checked for typos using diff but it’s still not working. I’m wondering if I need to start over and try again? Any advice would be great.
When I trying to connect to the guest SSID on the phone it just says “obtaining IP address…” but it never connects. When I connect to guest on a pc it connects but only with an IPV6 address (no IPV4 address) and it doesn’t actually connect to the internet. This is only an issue with the guest network.
