2021-10-18T09:40:10+02:00 console.gl-inet.c om dropbear[8847]: Child connection from 192.168.8.158:52928
2021-10-18T09:40:12+02:00 console.gl-inet.c om dropbear[8847]: Pubkey auth succeeded for ‘root’ with key md5 XXXXXXXX from 192.168.8.158:52928
2021-10-18T09:40:12+02:00 console.gl-inet.c om dropbear[8847]: Exit (root): Exited normally
2021-10-18T09:40:23+02:00 console.gl-inet.c om procd: - shutdown -
2021-10-18T09:40:24+02:00 console.gl-inet.c om ddns-scripts[3951]: glddns: PID ‘3951’ terminated by ‘SIGTERM’ at 2021-10-18 09:40
2021-10-18T09:40:24+02:00 console.gl-inet.c om dropbear[9106]: Early exit: Terminated by signal
2021-10-18T09:40:24+02:00 console.gl-inet.c om procd: Command failed: Not found
Can I log something else to get more detailed info about which process is at fault? Those dropbear[8847]: Pubkey auth succeeded come from the other mesh node and keep happening all the time (which is OK?).
Ive been using this unit in the repeater mode for about a year, so its not faulty. Both nodes have been updated, fresh settings and then formed the mesh.
Its from rsyslog running on another machine (remote logging). As you can see in the middle it says console.gl-inet.c om procd: - shutdown -. Id like to get a more detailed log from procd, to find out what causes the shutdown.
Thanks, this solved it. I can also see that 3.203 doesnt show up in autoupdate, I guess you completely reverted it.
I was also able to confirm that the 2nd mesh node caused those reboots. Simply by not being in its range for 2d12h, as its in the office. After about 4h of usage on monday the main node rebooted again.
