I am trying to use my External HDD on my new GL-B1300 for filesharing, however it doesn’t seem to be working. My router works with small usb drives but not this one.
My external HDD does work with my GL-MT300N-V2 however, so I’m not sure why it isn’t working with the GL-B1300.
Here are the system logs.
Fri May 29 23:42:40 2020 kern.warn kernel: [ 670.451835] hif_disable: Xhif_napi_destroy: NAPI 6 destroyed
Fri May 29 23:42:40 2020 kern.warn kernel: [ 670.457343] hif_napi_destroy: no NAPI instances. Zapped.ath_sysfs_diag_fini: diag_fsattr
Fri May 29 23:43:00 2020 kern.info kernel: [ 690.580126] usb 2-1: USB disconnect, device number 2
Fri May 29 23:43:04 2020 kern.info kernel: [ 694.548695] usb 2-1: new SuperSpeed USB device number 3 using xhci-hcd
Fri May 29 23:52:15 2020 daemon.info hostapd: ath1: STA 04:d3:b0:4d:3f:73 WPA: group key handshake completed (RSN)
Fri May 29 23:54:10 2020 kern.info kernel: [ 1360.425011] usb 2-1: USB disconnect, device number 3
Fri May 29 23:54:12 2020 kern.info kernel: [ 1362.798588] usb 2-1: new SuperSpeed USB device number 4 using xhci-hcd
Sat May 30 00:02:15 2020 daemon.info hostapd: ath1: STA 04:d3:b0:4d:3f:73 WPA: group key handshake completed (RSN)
Sat May 30 00:03:21 2020 daemon.info hostapd: ath1: STA 58:2f:40:14:3f:1e IEEE 802.11: associated
Sat May 30 00:03:21 2020 daemon.info hostapd: ath1: STA 58:2f:40:14:3f:1e RADIUS: starting accounting session 6240ECF22480A67A
Sat May 30 00:03:21 2020 daemon.info hostapd: ath1: STA 58:2f:40:14:3f:1e WPA: pairwise key handshake completed (RSN)
Sat May 30 00:03:25 2020 daemon.info dnsmasq-dhcp[2285]: DHCPDISCOVER(br-lan) 58:2f:40:14:3f:1e
No I’m not, but it worked on my little mango router fine. Is there a way to check for certain this is the issue before I got out and buy a powered usb hub?
