What issues were you having? Might help the developers out if they know what they need to work on.
No good “complaining” if the devs don’t know what the issues are.
Cheers.
Cheers.
This isn’t the place for bug or defect tracking.
I wasn’t complaining.
Hahaha that’s why I put complaining in quote marks.
If you can tell them why you’ve gone back to stable though hopefully it points them in the right direction as there’s no real defect/bug reporting system for users and at least this thread appears to be getting some traction.
Cheers.
It will be updated tomorrow(20220125).
For ZigBee, I have given feedback to the relevant people.
@lizh
Appreciate. But of course don’t push to meet that deadline. If you need more time to give us a better/stabler version, then take more time, just let us know
Upgrade
Upgrade from 3.211 1-10 went smoothly and all came back up
Clients now show per node
Wireguard server working fine
Goodcloud access works but only shows devices attached to the main node
Advanced option in More Settings
LUCI installed via Advanced option
Thank you for that.
Compared to other model firmwares:
Still no remove unattached client
No remote SSH/Web inteface from Goodcloud
What will be the upgrade program going forward for the Velica?
Goodcloud access works but only shows devices attached to the main node。
—》For MESH mode,Which shows only Main Node.
—》 Goodcloud has enabled permissions,You can use it now.
—》 It will update as soon as possible
