I'm seeing that the Beta section of the Download web has been removed for this model:
Is this a web error?
Not error.
Soon you will find that there is a new v4.7.x firmware.
I just upgrade my Marble from FW 4.5.22(stable) to beta FW 4.7.15 with keep settings, after the upgrade first reboot, the GL-iNET GUI interface is totally gone, it redirect the management interface to Luci instead and you can't find(access) the GL-iNET GUI anymore. ![]()
Release notes of the 4.7.15 firmware says that LuCi is no longer preinstalled. Could be this a side effect of the update?
Anything for 4.8.0 for marble ?
Maybe and this should have a precaution to not keep settings or something before user upgrade the same path just like me.
I will keep this in account. Thanks.
One more thing, after resetting to factory status and reinstall FW 4.7.15, the Luci needed to be manually installed. (release note noted)
After installing the Luci, when press the Luci button, it will redirect URL to https://192.168.8.1:8443 and noting is there (no content shown), it get weird even more. ![]()
Edit: after rebooting it again, it's back to normal Luci URL: http://192.168.8.1:8080/cgi-bin/luci/
Yes, this is noted in the release notes of the update. And LuCi needs to be installed as a independent package to be available.
We are working hard on the v4.8 beta firmware for multiple models. There are some obstacles currently encountered, some issues need to be resolved and improved before releasing this firmware.
Please wait.
So my B3000 will receive 4.8 firmware... Cool!
The only thing I ask is for maximum stability on that future firmware. Firmware 4.5 is working for me wonderfully. Firmware 4.7 (as I have tested too) is making a lot of good progress too.
