GL-B3000 Marble – Issue with Automatic Deletion of LAN Address Reservations
Why does the GL-B3000 Marble router automatically delete LAN address reservations?
I have a problem where, despite setting LAN address reservations, the settings reset after a few days, and the entire table disappears. The DHCP server then assigns new addresses.
Current Firmware
Version
4.5.19
Do you set the address reservation in GL GUI > Network > LAN, or are you configured in Luci > Network > DHCP?
Generally after configuring in GL GUI, and do not change anything in Luci about the address reservation and related settings.
I made the reservation in this place:
And that's all
I'm not reproducing the issue on my router.
SSH: cat /etc/config/dhcp
If the problem reappears, you can check the configuration file cat /etc/config/dhcp on the SSH, to see if there are MAC record.
For few days i hade this reservation and next 2 times router delete this settings without my confirmation
Please check the configuation by SSH to router with cat /etc/config/dhcp.
When you set up reservation, and check it once.
When the reservation lost, check it once again.
