[GL-BE14000 / Flint 4] Firmware v4.11.0 – Critical Mesh Backhaul Bug: Out-of-the-box ~100 Mbps cap & lack of 10G SFP+ / 10G WAN Ethernet Backhaul support
Hardware & Firmware Setup:
  • Devices: 2x GL.iNet GL-BE14000 (Flint 4)
  • Firmware Version: v4.11.0 (OpenWrt 25.12-SNAPSHOT, r32295+917-c25265953b)
  • ISP Link: 2 Gbps / 600 Mbps fiber connected to Main Router 2.5GbE WAN (eth2). Direct Speedtest on Main Router (via 2.5GbE LAN) confirms full 2108.62 Mbps down / 613.54 Mbps up.
  • Backhaul Physical Connection: Direct 10G SFP+ fiber link between Main Router 10G SFP+ LAN (eth1.1, port 4) and Mesh Agent (Satellite) 10G SFP+ port (eth1.2).
Problem Description:
  1. Out-of-the-Box Mesh Failure & ~95–100 Mbps Bottleneck (Before Manual LuCI Reconfiguration):
    • On default factory settings in Mesh mode, the GL-BE14000 completely fails to establish an Ethernet Backhaul over the 10G SFP+ fiber link (eth1.2).
    • Because the firmware binds eth1.2 to secondwan while gl-mesh / prplMesh (beerocks) listens exclusively on the copper eth2 port for wan, the Mesh Agent falls back to a degraded Wireless Backhaul (apclii0) and/or mismatched interface routing, capping client throughput at ~94.7 Mbps (100 Mbps class) despite a 2 Gbps ISP connection and 2.5GbE/10G hardware.
    • Furthermore, the Ethernet Backhaul onboarding wizard in v4.11.0 fails to auto-detect the node over fiber/cable unless the node is first manually switched to Mesh Node mode and paired via Wi-Fi scan.
  2. Results After Manual LuCI Reconfiguration (Test Environment Workaround):
    • The ~840–1025 Mbps throughput figures below were only achieved after manually reconfiguring network interfaces and bridges in LuCI for testing purposes (reassigning wan from eth2 to eth1.2, enabling STP on br-lan, and manually adding eth1.2 to br-lan).
    • Even with this manual LuCI workaround and a confirmed 10 Gbps physical SFP+ link (eth1.1 = 10Gbps, eth1.2 = 10000), traffic on the Mesh Agent starts with a brief burst (>1.16 Gbps) and immediately throttles down to ~840–1025 Mbps (whereas the Main Router delivers a steady 2108.62 Mbps).
    • The Mesh topology UI (192.168.8.1/#/mesh) still displays the blue Wi-Fi icon instead of the Ethernet backhaul icon, and beerocks_agent / gl-mesh VLAN filtering (ts_guest_vid '4002', ts_iot_vid '4003') on br-lan appears to disable MT7988A PPE hardware flow offloading for bridged traffic.
  3. Entire Ethernet Backhaul Architecture Needs Fixing for 10G Ports:
    • The GL-BE14000 is marketed and equipped with 10G SFP+ and 10GE WAN/LAN 1 ports. The Mesh backhaul engine (gl-mesh / prplMesh) must be updated so that any port configured or used as WAN—specifically the 10G SFP+ port (eth1.2) and the 10GE RJ45 WAN/LAN1 port—natively supports 10 Gbps Ethernet Backhaul out of the box with full hardware acceleration, without hardcoding eth2 or requiring manual LuCI bridge workarounds.
Diagnostic Logs & Evidence:
  1. Physical SFP+ 10G Link Negotiation (logread & /sys):
    Plaintext
    yt92xx yt92xx.0: eth1.1(port 4, sfp) link up, speed 10Gbps
    # On Satellite:
    cat /sys/class/net/eth1.2/speed -> 10000
  2. LuCI Interface State on Mesh Agent (After Manual Reconfiguration):
    Plaintext
    Interface: wan
    Device: eth1.2
    Protocol: Unmanaged
    Carrier: Present
  3. Active Mesh Processes & Config on Satellite:
    Plaintext
    /opt/prplmesh/bin/beerocks_agent
    /opt/prplmesh/bin/beerocks_fronthaul
    /usr/bin/eco /usr/sbin/gl-mesh
    Plaintext
    config base
        option enabled '1'
        option mode 'agent'
        option log_level 'DEBUG'
        option log_path '/var/log/gl-mesh'
        option onboard '1'
        option new_join_confirmed '1'
        option ts_enabled '1'
        option ts_guest_vid '4002'
        option ts_iot_vid '4003'
        option wan_proto_backup 'dhcp'
Requested Fix:
Please overhaul the gl-mesh and prplMesh (beerocks) Ethernet Backhaul implementation for GL-BE14000 (v4.11.x) so that:
  1. 10G SFP+ (eth1.2) and 10GE WAN/LAN 1 (as well as any active WAN port) are automatically detected and supported as 10 Gbps Ethernet Backhaul out of the box.
  2. Hardware acceleration (PPE / Flow Offloading) works properly across the backhaul link so clients connected to the Mesh Agent achieve the full 2+ Gbps ISP throughput instead of dropping from ~100 Mbps (stock) or ~850–1025 Mbps (manual LuCI bridge).
GL.iNet Flint 4 (GL-BE14000) – Krytyczny błąd Mesh Backhaul w firmware v4.11.0: ograniczenie do ~100 Mb/s na ustawieniach fabrycznych oraz brak obsługi 10G SFP+ i 10G WAN
Opis problemu:
Zakupiłem dwa routery GL.iNet Flint 4 (GL-BE14000) w celu zbudowania sieci Mesh połączonej bezpośrednim łączem światłowodowym 10 Gb/s (SFP+ ↔ SFP+) przy łączu internetowym 2 Gb/s / 600 Mb/s.
  1. Stan fabryczny – brak wykrywania światłowodu 10G SFP+ i spadek prędkości do ~95–100 Mb/s:
    • Na domyślnej konfiguracji fabrycznej mechanizm Mesh całkowicie ignoruje połączenie światłowodowe 10G SFP+ (eth1.2), ponieważ port ten jest domyślnie przypisany jako secondwan, a demon Mesh (gl-mesh / prplMesh) nasłuchuje wyłącznie na porcie eth2.
    • W efekcie satelita spina się po degradowanym łączu radiowym (Wireless Backhaul) z błędnym trasowaniem interfejsów, co ogranicza przepustowość u klienta do zaledwie ~94,7 Mb/s (poziom 100 Mb/s) mimo łącza 2 Gb/s i portów 2.5GE/10GE.
  2. Wyniki po ręcznej rekonfiguracji interfejsów w LuCI (środowisko testowe):
    • Wynik na poziomie ~840–1025 Mb/s udało się uzyskać dopiero po ręcznej rekonfiguracji interfejsów i mostków w panelu LuCI w celach testowych (przepięciu interfejsu wan z eth2 na światłowodowy eth1.2, włączeniu protokołu STP na br-lan oraz ręcznym dopięciu eth1.2 do mostka br-lan).
    • Mimo poprawnej negocjacji obu wkładek SFP+ na pełne 10 Gb/s (eth1.1 = 10Gbps, eth1.2 = 10000), ruch na satelicie w pierwszej sekundzie testu przekracza 1,16 Gb/s, po czym zostaje zdławiony do ~840–1025 Mb/s (podczas gdy na routerze głównym osiąga stabilne 2108,62 Mb/s), a panel Mesh nadal błędnie wyświetla ikonę Wi-Fi zamiast połączenia kablowego.
  3. Konieczność poprawy całego mechanizmu Ethernet Backhaul pod kątem portów 10G:
    • Cały mechanizm Ethernet Backhaul w oprogramowaniu GL.iNet dla modelu GL-BE14000 wymaga poprawki inżynieryjnej — węzeł Mesh musi natywnie obsługiwać połączenie 10 Gb/s Ethernet Backhaul po światłowodzie (SFP+), po porcie 10GE WAN/LAN 1, a także na każdym innym porcie skonfigurowanym jako WAN, z pełną akceleracją sprzętową i bez konieczności ręcznego modyfikowania mostków w LuCI.
The 4.11.0 beta firmware on the Flint 4 not supporting SFP+ for the backhaul on mesh is a known limitation at the time.
