I have problems with FLINT 4 SFP cage and DAC or multimode transceivers.
I know that DAC usually are not very compatible and sometimes AWG number is important too, the higher (thinner) the better.
In my experience, all DAC cables I have work with ASUS XG-C100F PC-card and with Mikrotik CRS309-1G-8S+ router.
Inserting one end in the ASUS XG-C100F card I tried to establish connection putting in the FLINT SFP cage:
case A: 10Gtek DAC cable "10GBase-CU DAC 2m 30AWG passive"
mod. CAB-10GSFP-P2M flint says: EEPROM not recognized
case B: 10Gtek DAC cable "10GBase-CU DAC 5m 26AWG passive"
mod. CAB-10GSFP-P5M flint says: EEPROM not recognized
case C: 10Gtek transceivers 2x "10GBase=SR 850nm 300m" with OM5 patchcord 10m
mod. AXS85-192-M3 flint says: EEPROM recognized but no connection
to investigate I made a little test program and it writes this (with transceivers / case C:)
SFPMON
MODULE: PRESENT
SFP+ EEPROM A0: READOK
VENDOR: OEM | PART-NO: 10GBASE-SR
REVISION: 02 | SERIAL: CS105O54XXX | DATE: 240527
HWMON
PARAMETER VALUE MIN MAX CRIT
TEMPERATURE 48.906 C 0.000 70.000 80.000
VCC 3.273 V 3.135 3.465 3.630
TX BIAS 6.000 mA 3.000 12.000 15.000
TX POWER 597.000 uW 178.000 1000.000 1585.000
RX POWER 600.000 uW 62.000 1000.000 1585.000
S: dBm /[uW] R: REFRESH Q: QUIT
but my PC tells me this: (from ipconfig /all)
Ethernet adapter Ethernet 2:
Media State . . . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . . . : lan
Description . . . . . . . . . . . . . : ASUS XG-C100F 10G SFP+ Network Adapter
Physical Address. . . . . . . . . . . : C8-7F-54-90-XX-XX
DHCP Enabled. . . . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . . . : Yes
Of course, flint SFP is set as LAN.
Can you please give me some tips on how to get the SFP port working?
Thank you
