GL-BE14000 - Flint 4 Mesh Bug Report
Flint 4 - Main Mesh with two nodes …
Flint 3 - Node Ethernet
Also same issue on WiFi. Crash every day or two.
This log actually catches the failure quite clearly.
At about 08:57:25, the Flint 4’s MediaTek Ethernet subsystem starts locking up:
NETDEV WATCHDOG ... eth2: transmit queue 2 timed out
Then it repeats continuously on both eth2 and eth1, with the timeout climbing from ~5 seconds to ~65 seconds. Pasted markdown Pasted markdown
What happened
Immediately before that, your mesh/backhaul topology was changing. At 08:56:36 the Flint created a WDS/mesh interface (rai4.sta4), added it to the LAN bridge, and eventually put it into forwarding state. Pasted markdown
Then you start seeing repeated topology-change BPDUs. Shortly afterward, the physical Ethernet link itself drops and comes back:
08:57:30: LAN1 link down
08:57:33: LAN1 comes back at 2.5 Gbps
08:57:35: both Flint 3 nodes obtain DHCP addresses again. Pasted markdown Pasted markdown
But the Ethernet transmit queues don't recover. The watchdog errors continue over and over. That's why the network appears to effectively freeze/crash even though the router itself hasn't necessarily rebooted.
The interesting part
This looks much more like a Flint 4 beta firmware / MediaTek Ethernet-driver + mesh/backhaul problem than an ISP problem.
In particular, you've now got wired Ethernet backhaul between the Flint 4 and Flint 3s, while the firmware is also creating WDS/mesh bridge interfaces. The repeated:
received tcn bpdu
topology change detected
is consistent with the bridge repeatedly reacting to topology changes. Pasted markdown
Then the MediaTek Ethernet driver goes into the fatal-looking condition:
NETDEV WATCHDOG: transmit queue ... timed out
That's the smoking gun.
The log strongly supports a MediaTek Ethernet/QDMA transmit-queue hang, but it does not yet prove that the mesh topology changes caused it. The TCN BPDUs and link flap may be triggers or consequences; they are not by themselves evidence of a network loop.
Please provide the exact firmware version/build date and the Network Acceleration mode used during this failure. As a targeted comparison, set Network Acceleration to None and observe for at least the usual 1–2 day failure interval. If the watchdog timeout still occurs, export the system log before rebooting and send it privately to a GL.iNet support member with the approximate failure time and port topology; please do not publish the complete log. This comparison will help separate the hardware-offload path from the underlying Ethernet/mesh driver path.
Thank you for your feedback.
Could you please help by providing the following information?
  1. Are both Flint 3 nodes connected directly to the Flint 4 via Ethernet, or through a switch?
  2. Does it still happen when both Flint 3 nodes use wireless backhaul only, with Ethernet disconnected?
  3. When the issue occurs, could you briefly describe the network status? For example, are both wired and wireless clients affected, whether the Flint 4 Web Admin Panel is still accessible and whether a reboot is required to restore the connection?
  4. If the issue occurs again, could you please export the System logs from the Flint 4 and both Flint 3 Mesh nodes, and send them to us via private message?
Thank you for your patience and cooperation.
How to send private messages:
