GL-BE3600 doesn't connect to the hotel hotspot with captive
Dear Support team,
I am trying to connect GL-BE3600 (Slate 7) to the hotel hotspot which has a captive where I must enter a password. Non of the recommended options worked, including cloning of the Mac Address of my laptop. All other devices can connect without any issues.
Have you tried other steps in this tutorial, such as enabling ‘Public Hotspot Login Mode & Camouflage’?
Hey Will,
Yes, I tried all options from the official documentation and with different combinations.
After reading syslogs I found that it was connecting to the BSSID and then immediately disconnecting (can’t find the exact log now though). What helped is to manually move Repeater to 2.4 GHz mode instead of auto. My theory is that it was not working well with 5Ghz DFS Hotel hotspot. Once you forced it to the 2.4GHz it connected without any issues. Which is still surprising since other devices working just fine using 5Ghz.
if it will be useful I can try to find logs of what exactly was happening, if it can help improving future versions of firmware.
Thank you for the update.
Yes, if you can provide the logs, we can see exactly what happened and provid to the R&D team for future version improvements.
Here is the log I used to identify the problem:
Fri Aug 29 23:53:01 2025 daemon.info gl-repeater[3998]: (repeater.lua:1022) switch to any...
Fri Aug 29 23:53:02 2025 daemon.info gl-repeater[3998]: (repeater.lua:923) connecting to bss: GuestGHC 2c:ab:46:af:a7:b0 136 none
Fri Aug 29 23:53:02 2025 daemon.notice netifd: wifi1 (23782): WARNING: Variable 'mld' does not exist or is not an array/object
Fri Aug 29 23:53:02 2025 user.warn kernel: [ 2068.068668] CALLER: /usr/bin/lua/usr/sbin/qca-wifi-configurator, PID: 3889 arg: disable multi_up
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.205389] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:1 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.226711] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:2 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.246450] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:3 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.268650] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:4 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.289446] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:5 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.311582] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:6 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.332175] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:7 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.350488] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:8 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.453850] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:9 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.476552] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:10 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.496653] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:11 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.516867] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:12 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.536498] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:13 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.555532] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:14 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.575170] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:15 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.594941] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:16 is disabled
Fri Aug 29 23:53:02 2025 kern.err kernel: [ 2068.613897] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:17 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.633931] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:18 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.653042] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:19 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.675937] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:20 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.695302] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:121 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.714528] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:122 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.737445] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:123 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.757791] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:124 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.781359] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:125 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.800921] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:126 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.819534] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:127 is disabled
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2068.838395] wlan: [0:I:ANY] ieee80211_ucfg_sawf_disable: Service class ID:128 is disabled
Fri Aug 29 23:53:03 2025 user.warn kernel: [ 2069.108384] CALLER: /usr/bin/lua/usr/sbin/qca-wifi-configurator, PID: 3889 arg: enable
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.363542] wlan: [24211:I:MBSSIE] osif_mbssid_sanity_check: mbssid_sanity_ok: YES
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.363575] wlan: [24211:I:ANY] osifp_create_wlan_vap: No cloning
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.370067] wlan: [24211:I:ANY] osifp_create_wlan_vap: VDEV Create 1e:71:b6:d5:77:0c
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.376196] wlan: [24211:I:ANY] osifp_create_wlan_vap: mlo_mbssid disabled in lower band radios
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.384073] wlan: [24211:I:ANY] wlan_vap_create: devhandle=0x0000000042e2263a, opmode=IEEE80211_M_STA, flags=0x2
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.394280] wlan: [24211:E:ANY] ol_ath_set_mec_timer: vdev is NULL
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.406247] wlan: [24211:I:ANY] ol_ath_vap_set_param: VDEV params:EHT su_bfee:1|su_bfer:1|mu_bfee:0|mu_bfer:0|dl_ofdma:1|ul_ofdma:1|ulmumimo:1|dl_muofdma_bfer:1|dl_muofdma_mumimo:0|ul_muofdma_mumimo:0
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.411765] wlan: [24211:I:ANY] ol_ath_vap_set_param: eht_mu_bf_mode=0xf3
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.429934] wlan: [24211:E:ANY] wlan_create_attach_vdev_rawsim_ctxt: simulation module not registerd
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.436932] wlan: [24211:I:ANY] osif_pltfrm_create_ppe_vp: vp user type: ds vpai.core_mask: 7 target type: 39 vpnum: 68 icp_flags: 400002
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.445637] wlan: [24211:I:ANY] osif_pltfrm_create_ppe_vp_802_3_redir_vap:
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.445637] dev:00000000d033aaa2, dev->name:sta1 osnetdev:00000000938acf1b, allocated VP # 68
Fri Aug 29 23:53:03 2025 kern.err kernel: [ 2069.459580] wlan: [24211:I:RPTR] RPTR vdev flags:0 pdev flags:0 vdev_id:2 pdev_id:0
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2069.913048] wlan: [24348:I:ANY] DES SSID SET=GuestGHC
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.190898] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5260MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.190933] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5280MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.199860] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5300MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.209115] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5320MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.218612] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5500MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.227976] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5520MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.237439] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5540MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.246826] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5560MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.256328] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5580MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.265752] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5600MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.275311] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5620MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.284698] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5640MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.294162] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5660MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.303598] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5680MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.313094] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5700MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.322456] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5745MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.331986] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5765MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.341396] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5785MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.350843] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5805MHz) is already in the list
Fri Aug 29 23:53:04 2025 kern.err kernel: [ 2070.360304] wlan: [24547:I:ANY] wlan_acs_block_channel_list: [EXT] Freq (5825MHz) is already in the list
Fri Aug 29 23:53:04 2025 daemon.err insmod: module is already loaded - ecm-wifi-plugin
Fri Aug 29 23:53:05 2025 kern.info kernel: [ 2071.035071] 8021q: adding VLAN 0 to HW filter on device sta1
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2071.905813] device mld0 left promiscuous mode
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2071.905837] device wlan02 left promiscuous mode
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2071.909518] device wlan12 left promiscuous mode
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2071.914214] br-lan: port 3(mld0) entered disabled state
Fri Aug 29 23:53:06 2025 daemon.notice netifd: Network device 'mld0' link is up
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2071.992367] br-lan: port 3(mld0) entered blocking state
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2071.992394] br-lan: port 3(mld0) entered disabled state
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2072.001230] device mld0 entered promiscuous mode
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2072.001597] device wlan02 entered promiscuous mode
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2072.006723] device wlan12 entered promiscuous mode
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2072.011630] br-lan: port 3(mld0) entered blocking state
Fri Aug 29 23:53:06 2025 kern.info kernel: [ 2072.015903] br-lan: port 3(mld0) entered forwarding state
Fri Aug 29 23:53:06 2025 kern.err kernel: [ 2072.138794] wlan: [0:I:CMN_MLME] Sending ucast disassoc to PMF associated stas
Fri Aug 29 23:53:06 2025 kern.err kernel: [ 2072.140876] wlan: [0:I:CMN_MLME] mlme_ext_vap_down: VAP (wlan1) 42:2d:54:0f:66:b9 is down
Fri Aug 29 23:53:06 2025 daemon.info hostapd: wlan12: STA be:1e:ba:77:cf:e8 IEEE 802.11: disassociated
Fri Aug 29 23:53:06 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 IEEE 802.11: authenticated
Fri Aug 29 23:53:06 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 IEEE 802.11: disassociated
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 IEEE 802.11: associated (aid 1)
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 WPA: sending 1/4 msg of 4-Way Handshake
Fri Aug 29 23:53:07 2025 kern.err kernel: [ 2072.906500] wlan: [6933:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan02
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 WPA: received EAPOL-Key frame (2/4 Pairwise)
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 WPA: sending 3/4 msg of 4-Way Handshake
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 WPA: received EAPOL-Key frame (4/4 Pairwise)
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 RADIUS: starting accounting session 866795EC0706645E
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan02: STA be:1e:ba:77:cf:e8 WPA: pairwise key handshake completed (RSN)
Fri Aug 29 23:53:07 2025 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.176 be:1e:ba:77:cf:e8
Fri Aug 29 23:53:07 2025 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.176 be:1e:ba:77:cf:e8 Mac
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.008179] SAWF Telemetry: sawf_ctx->mov_avg.packet 1000
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.008184] SAWF Telemetry: sawf_ctx->mov_avg.window 10
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.008192] SAWF Telemetry: sawf_ctx->sla_param.num_packets10000
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.008195] SAWF Telemetry: sawf_ctx->sla_param.time_secs10
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171750] SAWF Telemetry: Service ID: 126
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171758] SAWF Telemetry: cfg->min_thruput_rate 95
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171761] SAWF Telemetry: cfg->max_thruput_rate 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171763] SAWF Telemetry: cfg->burst_size 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171766] SAWF Telemetry: cfg->service_interval 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171768] SAWF Telemetry: cfg->delay_bound 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171771] SAWF Telemetry: cfg->msdu_ttl 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.171773] SAWF Telemetry: cfg->msdu_rate_loss 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191477] SAWF Telemetry: Service ID: 127
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191485] SAWF Telemetry: cfg->min_thruput_rate 95
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191488] SAWF Telemetry: cfg->max_thruput_rate 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191490] SAWF Telemetry: cfg->burst_size 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191493] SAWF Telemetry: cfg->service_interval 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191495] SAWF Telemetry: cfg->delay_bound 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191497] SAWF Telemetry: cfg->msdu_ttl 0
Fri Aug 29 23:53:07 2025 daemon.info hostapd: wlan12: STA 82:50:53:ef:21:4f IEEE 802.11: disassociated
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.191500] SAWF Telemetry: cfg->msdu_rate_loss 0
Fri Aug 29 23:53:07 2025 kern.err kernel: [ 2073.195153] wlan: [0:I:CMN_MLME] mlme_ext_vap_down: VAP (wlan12) 26:5c:09:46:27:ec is down
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210821] SAWF Telemetry: Service ID: 128
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210825] SAWF Telemetry: cfg->min_thruput_rate 95
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210832] SAWF Telemetry: cfg->max_thruput_rate 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210835] SAWF Telemetry: cfg->burst_size 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210837] SAWF Telemetry: cfg->service_interval 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210839] SAWF Telemetry: cfg->delay_bound 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210842] SAWF Telemetry: cfg->msdu_ttl 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.210844] SAWF Telemetry: cfg->msdu_rate_loss 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237403] SAWF Telemetry: type 0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237411] SAWF Telemetry: detect->min_thruput_rate:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237414] SAWF Telemetry: detect->max_thruput_rate:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237417] SAWF Telemetry: detect->burst_size:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237419] SAWF Telemetry: detect->service_interval:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237421] SAWF Telemetry: detect->delay_bound:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237424] SAWF Telemetry: detect->msdu_ttl:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.237426] SAWF Telemetry: detect->msdu_rate_loss:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241965] SAWF Telemetry: type 1
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241974] SAWF Telemetry: detect->min_thruput_rate:1
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241976] SAWF Telemetry: detect->max_thruput_rate:1
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241979] SAWF Telemetry: detect->burst_size:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241981] SAWF Telemetry: detect->service_interval:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241984] SAWF Telemetry: detect->delay_bound:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241986] SAWF Telemetry: detect->msdu_ttl:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.241989] SAWF Telemetry: detect->msdu_rate_loss:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246510] SAWF Telemetry: type 2
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246517] SAWF Telemetry: detect->min_thruput_rate:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246520] SAWF Telemetry: detect->max_thruput_rate:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246522] SAWF Telemetry: detect->burst_size:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246525] SAWF Telemetry: detect->service_interval:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246527] SAWF Telemetry: detect->delay_bound:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246530] SAWF Telemetry: detect->msdu_ttl:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.246532] SAWF Telemetry: detect->msdu_rate_loss:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250782] SAWF Telemetry: type 3
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250790] SAWF Telemetry: detect->min_thruput_rate:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250793] SAWF Telemetry: detect->max_thruput_rate:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250795] SAWF Telemetry: detect->burst_size:1
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250798] SAWF Telemetry: detect->service_interval:1
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250800] SAWF Telemetry: detect->delay_bound:0
Fri Aug 29 23:53:07 2025 kern.debug kernel: [ 2073.250802] SAWF Telemetry: detect->msdu_ttl:1
Fri Aug 29 23:53:07 2025 daemon.notice netifd: Wireless device 'wifi1' is now up
Fri Aug 29 23:53:08 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f IEEE 802.11: authenticated
Fri Aug 29 23:53:08 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f IEEE 802.11: disassociated
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f IEEE 802.11: associated (aid 2)
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f WPA: sending 1/4 msg of 4-Way Handshake
Fri Aug 29 23:53:09 2025 kern.debug kernel: [ 2073.250805] SAWF Telemetry: detect->msdu_rate_loss:1
Fri Aug 29 23:53:09 2025 kern.err kernel: [ 2074.665566] wlan: [6933:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan02
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f WPA: received EAPOL-Key frame (2/4 Pairwise)
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f WPA: sending 3/4 msg of 4-Way Handshake
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f WPA: received EAPOL-Key frame (4/4 Pairwise)
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f RADIUS: starting accounting session 3897BFDD713C2BAD
Fri Aug 29 23:53:09 2025 daemon.info hostapd: wlan02: STA 82:50:53:ef:21:4f WPA: pairwise key handshake completed (RSN)
Fri Aug 29 23:53:12 2025 kern.err kernel: [ 2078.200329] wlan: [6932:I:ANY] wlan_cfg80211_get_wideband_support: Sending wideband support: 0
Fri Aug 29 23:53:12 2025 kern.err kernel: [ 2078.202381] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES SSID SET=GuestGHC!
Fri Aug 29 23:53:12 2025 kern.err kernel: [ 2078.207931] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES BSSID SET=2c:ab:46:af:a7:b0
Fri Aug 29 23:53:12 2025 kern.err kernel: [ 2078.232694] wlan: [5441:E:mlme] mlme_cmd_abort: Active cmd not found type:31
Fri Aug 29 23:53:12 2025 kern.err kernel: [ 2078.233114] wlan: [78:I:ANY] [UNSPECIFIED] vap-2(sta1):osif_vap_xmit_queue: wbuf xmit failed
Fri Aug 29 23:53:14 2025 kern.err kernel: [ 2080.024663] wlan: [6932:I:ANY] wlan_cfg80211_get_wideband_support: Sending wideband support: 0
Fri Aug 29 23:53:14 2025 kern.err kernel: [ 2080.026821] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES SSID SET=GuestGHC!
Fri Aug 29 23:53:14 2025 kern.err kernel: [ 2080.032166] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES BSSID SET=2c:ab:46:af:a7:b0
Fri Aug 29 23:53:14 2025 kern.err kernel: [ 2080.039682] wlan: [0:I:CMN_MLME] cm_connect_get_candidates: vdev 2 cm_id 0xc020002: no valid candidate found, num_bss 0 scan_id 0
Fri Aug 29 23:53:14 2025 kern.err kernel: [ 2080.372748] wlan: [5441:E:mlme] mlme_cmd_abort: Active cmd not found type:31
Fri Aug 29 23:53:16 2025 kern.err kernel: [ 2082.564926] wlan: [6932:I:ANY] wlan_cfg80211_get_wideband_support: Sending wideband support: 0
Fri Aug 29 23:53:16 2025 kern.err kernel: [ 2082.567017] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES SSID SET=GuestGHC!
Fri Aug 29 23:53:16 2025 kern.err kernel: [ 2082.572429] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES BSSID SET=2c:ab:46:af:a7:b0
Fri Aug 29 23:53:16 2025 kern.err kernel: [ 2082.579916] wlan: [0:I:CMN_MLME] cm_connect_get_candidates: vdev 2 cm_id 0xc020003: no valid candidate found, num_bss 0 scan_id 0
Fri Aug 29 23:53:19 2025 kern.err kernel: [ 2085.605151] wlan: [6932:I:ANY] wlan_cfg80211_get_wideband_support: Sending wideband support: 0
Fri Aug 29 23:53:19 2025 kern.err kernel: [ 2085.607254] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES SSID SET=GuestGHC!
Fri Aug 29 23:53:19 2025 kern.err kernel: [ 2085.612679] wlan: [6932:I:ANY] wlan_cfg80211_connect: DES BSSID SET=2c:ab:46:af:a7:b0
Fri Aug 29 23:53:19 2025 kern.err kernel: [ 2085.620098] wlan: [0:I:CMN_MLME] cm_connect_get_candidates: vdev 2 cm_id 0xc020004: no valid candidate found, num_bss 0 scan_id 0
