GL-BE3600 Slate 7: Screen problem after v4.7.2-Update!
Just updated the GL-BE3600 Slate 7 to v4.7.2.
When it was finished, still the GL iNet Logo and the green progress bar show up on the screen, and no more other menus of functions are visible! No reactions from the screen.
The Router otherwise seems to work fine.
Screen settings can be made but nothing changes - always the same.
I reinstalled the v4.7.2 version from the GL iNet website and for a moment it shows the other logo but then changes back to the same Logo as before and the green progress bar. Screen seems to stay on. No changes so far.
What should I do now?
May I know did the router enable the HTTPS force in GL GUI > SYSTEM > Security > Admin Panel > Force HTTPS?
Ah okay I just saw there is another topic about this and turning "Force HTTPS" off solved it so far...
Thanks.
Thanks for confirmation.
We are checking this issue.
