So I finally installed this router in my network and I was dreading it for a good reason as it turned out. I'm running firmware 4.9. The following issues all took over four hours to resolve, I consider myself to be pretty good with IT an average user would have no hope and solving these things.
- wouldn't connect to broadband provider
I currently have sky broadband in the UK. I had to log onto Luci and enter the following Network > Interfaces > WAN > Advanced Setting > Client ID 616e797468696e6740736b7964736c7c3631363236333634
I was in the process of replacing the BT smart hub router that I previously had and instead of being tied to another ISP router I brought this router so that if I switch providers, so I don't need to worry about reconfiguring my network. The client ID was not required on the old BT smart hub router. in addition searching the Internet suggested that I should set the VLAN ID = 101 along with this client ID setting. Until I deleted the VLAN ID it wouldn't work only the client ID is required.. This was trial and error and only figured it out by trying different configurations. I understand this is potentially not a GL Inet problem but it was problematic for me and I think you should have this sort of information available for customers in the UK.
port forwarding didn't work, I think there's a known bug in the current firmware which means the settings are not applied in Luci even though they are in the normal administration user interface. immensely frustrating and took hours to debug.
network acceleration on by default, terrible… Turn it off straight away it caused all sorts of problems everything came alive as soon as I disabled it
I hope this helps future users
Thanks for sharing your experience, and sorry for the trouble during setup.
Sky Broadband requires DHCP Option 61 (client identifier), as noted in our troubleshooting guide. Your feedback about what worked in your setup is helpful.
Starting with firmware v4.9, port forwarding configured in the GL.iNet Admin Panel uses our own kernel module. These rules therefore do not appear in LuCI. This is expected; their absence from LuCI alone does not mean they were not applied.
If you are still experiencing issues with port forwarding or anything else, feel free to add more details here or contact support@gl-inet.com if you prefer private/email communication. We are always happy to provide further assistance.
Hi Will, I wonder if it was just the network acceleration that was causing the port forwarding not to work then… I could in theory test this
The only related bug regarding port forwarding with hardware acceleration enabled that we’re currently aware of affects NAT loopback: a device on your local network accessing another local server through your public IP address and a forwarded port. But this bug does not affect access from outside your network.
Yes, if you have the chance, please give it a try & tell us the specific port mapping setup and whether you are accessing it from an external network (such as a mobile device's hotspot in cellular network). If you encounter any issues, please feel free to share the details with us. We’ll be happy to help investigate further.
That is exactly the bug that I encountered. I have a monitoring system trying to access my websites via an external IP address. As soon as I disabled hardware acceleration, everything 'came back online' I had lots of warnings about traffic speed and hardware acceleration in the UI, which is why I decided to turn it off and try.
Thanks for clarifying. Please keep network acceleration disabled for now as a workaround.
This issue involves Qualcomm’s underlying hardware acceleration implementation. We’re still investigating and validating how to resolve it.
