GL-BE9300 Beszel Agent installation, MPTCP bug & System Crash
Hi everyone,
I wanted to share my experience installing Beszel Agent on a GL.iNet GL-BE9300. And asking for help.
While the installation process is standard for OpenWrt (aarch64), I ran into a critical MPTCP issue that eventually caused the router to drop all network connectivity.
Here is a summary so others can avoid bricking their connection.
System Info
Architecture: aarch64_cortex-a53_neon-vfpv4
Download and extract beszel agent
wget --no-check-certificate ``https://github.com/henrygd/beszel/releases/download/v0.17.0/beszel-agent_linux_arm64.tar.gz
tar -xzf beszel-agent_linux_arm64.tar.gz
chown root:root beszel-agent
The Beszel-agent file
KEY="ssh-ed25519 AAAAC3Nz..."
ADDR="192.168.1.1:45876"
start_service() {
procd_open_instance
procd_set_param command /usr/bin/beszel-agent
procd_append_param command -key "$KEY"
procd_append_param command -l "$ADDR"
procd_set_param respawn
procd_set_param stdout 1
procd_set_param stderr 1
procd_close_instance
Move to destination
mv beszel-agent /usr/bin/beszel-agent
chmod +x /usr/bin/beszel-agent
Creating the init script
(/etc/init.d/beszel-agent):
#!/bin/sh /etc/rc.common
START=99
USE_PROCD=1
Enabling the service:
chmod +x /etc/init.d/beszel-agent
/etc/init.d/beszel-agent enable
/etc/init.d/beszel-agent start
Firewall Configuration
Opening port 45876 for LAN access:
uci add firewall rule
uci set firewall.@rule\[-1\].name='Allow-Beszel'
uci set firewall.@rule\[-1\].src='lan'
uci set firewall.@rule\[-1\].proto='tcp'
uci set firewall.@rule\[-1\].dest_port='45876'
uci set firewall.@rule\[-1\].target='ACCEPT'
uci commit firewall
/etc/init.d/firewall restart
THE ISSUE: MPTCP
After configuration, the agent was running but failed to connect to the Beszel Hub (192.168.1.64 same LAN nothing special). The system logs showed repetitive kernel errors:
kern.err kernel: [2124650.832916] MPTCP: mptcp need to implement this function: net/mptcp/subflow.c,subflow_v4_init_req,1791It seems the MPTCP implementation in the GL-BE9300 kernel conflicts with how Beszel communicates.
The Fatal "Fix"
I attempted to disable MPTCP to resolve the error:
sysctl -w net.mptcp.enabled=0
Result: The agent immediately started working and connected successfully!
HOWEVER: After running for about 20-23 hours, the router completely lost internet connectivity. No WAN, no routing. The only solution was a hard reset and restoring settings from a backup.
Making this persistent via /etc/sysctl.d/99-disable-mptcp.conf seems to make the system unstable over time.
Conclusion:
On the current GL-BE9300 firmware, MPTCP appears to be buggy, blocking services like Beszel. However, disabling it leads to a system crash after a day.
Tip: Always keep a fresh backup before touching kernel parameters.
Question: How can I access my router 45876 port on my lan area? (No, vpn client not running)
Please try adding the following to the init script:
procd_set_param env GODEBUG=multipathtcp=0
Refer: Gl-inet router GL-MT3000 Beryl Update AGH to v0.107.59 from v0.107.57- error new wersion don't working · Issue #7749 · AdguardTeam/AdGuardHome · GitHub
It looks like working. Thank you for your help.
Just in case here my full /etc/init.d/beszel-agent script
START=99
USE_PROCD=1
# Config
PROG=/usr/bin/beszel-agent
KEY="ssh- key copy from beszel"
#EXTRA_DISK=""
start_service() {
    procd_open_instance
    procd_set_param command "$PROG"
    # Parameters
    if [ -n "$EXTRA_DISK" ]; then
        procd_append_param command -ef "$EXTRA_DISK"
    fi
    # Enable in AppArmor the MPTCP
    # Automatic restart
    procd_set_param respawn ${respawn_threshold:-3600} ${respawn_timeout:-5} ${respawn_retry:-5}
    # Logging
