Device:
GL-BE9300 (Flint 3)
Firmware:
4.9.0
Affected feature:
WAN Ethernet MAC Randomization - periodic mode
Configuration:
network.@device.name='eth0'
network.@device.mac_mode='r10080'
Description:
When WAN MAC randomization is enabled using periodic mode (for example r30, r60, r10080), the script:
/usr/sbin/gl-update-cable-mac.sh
incorrectly parses the period value from mac_mode.
Example:
mac_mode=r10080
Expected:
10080 minutes (7 days)
Actual:
The parsed value is incorrect, causing mac_expire to become invalid or already expired.
As a result, every cron execution runs the MAC update process again, changes the WAN MAC address and triggers a network reload, causing WAN disconnections.
Observed behaviour:
- WAN reconnect every 30 minutes
- PPPoE session interruption
- WAN MAC address changes unexpectedly
Debug evidence:
Command:
sh -x /usr/sbin/gl-update-cable-mac.sh time
Output attached.
Workaround:
Removing the following options stops the issue:
uci delete network.<wan_device>.mac_mode
uci delete network.<wan_device>.mac_expire
uci commit network
After removing these values, the script exits without triggering network reloads.
Possible fix:
The period extraction should only remove the leading "r".
Current logic:
sed 's/.([0-9]+)./\1/'
Possible replacement:
sed 's/^r//'
or:
sed 's/[^0-9]//g'
This issue may affect all periodic MAC randomization modes:
r30
r60
r1440
r10080
etc.
