My GL.iNet GL-BE9300 (factory reset, no custom configuration) keeps dropping
multiple Wi-Fi clients at once, several times a day. Devices disconnect in
quick succession, sometimes with the radio connection resetting.
The system log shows clients being kicked by the kernel with "excessive
retries", plus driver-level association errors. This happens on wlan1
(5 GHz), wlan16 (5 GHz IoT) and wlan06 (2.4 GHz).
Key errors:
wlan: [0:I:ANY] [INACT] vap-0(wlan1): [ae:b2:c6:41:b5:14]
station kicked out due to excessive retries associd 3 (from target) reason 2
wlan: [0:E:ANY] ieee80211_recv_asreq: assoc req from dms not-supported sta :...
Full log (system errors only):
Tue Oct 6 16:30:35 2026 kern.err kernel: [ 784.879932] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :c0:f8:53:a0:bb:4a
Tue Oct 6 17:34:33 2026 daemon.info hostapd: wlan1: STA 2e:01:9b:9f:a0:98 IEEE 802.11: disassociated
Tue Oct 6 17:56:33 2026 daemon.info hostapd: wlan1: STA 2e:01:9b:9f:a0:98 IEEE 802.11: disassociated
Tue Oct 6 18:11:24 2026 daemon.info hostapd: wlan1: STA 2e:01:9b:9f:a0:98 IEEE 802.11: disassociated
Tue Oct 6 18:11:45 2026 daemon.info hostapd: wlan1: STA ae:b2:c6:41:b5:14 IEEE 802.11: disassociated
Tue Oct 6 18:13:10 2026 daemon.info hostapd: wlan1: STA 2e:01:9b:9f:a0:98 IEEE 802.11: disassociated
Tue Oct 6 18:24:43 2026 daemon.info hostapd: wlan1: STA ae:b2:c6:41:b5:14 IEEE 802.11: disassociated
Tue Oct 6 18:24:43 2026 kern.err kernel: [ 7632.422218] wlan: [0:I:ANY] [INACT] vap-0(wlan1): [ae:b2:c6:41:b5:14]station kicked out due to excessive retries associd 3 (from target) reason 2
Tue Oct 6 20:37:34 2026 daemon.info hostapd: wlan1: STA ae:b2:c6:41:b5:14 IEEE 802.11: disassociated
Tue Oct 6 20:37:34 2026 kern.err kernel: [15603.410183] wlan: [0:I:ANY] [INACT] vap-0(wlan1): [ae:b2:c6:41:b5:14]station kicked out due to excessive retries associd 1 (from target) reason 1
Tue Oct 6 23:39:15 2026 daemon.info hostapd: wlan16: STA 3a:79:c7:b4:0d:a1 IEEE 802.11: disassociated
Tue Oct 6 23:39:15 2026 kern.err kernel: [26504.252286] wlan: [0:I:ANY] [INACT] vap-2(wlan16): [3a:79:c7:b4:0d:a1]station kicked out due to excessive retries associd 1 (from target) reason 2
Wed Oct 7 04:26:03 2026 daemon.info hostapd: wlan06: STA 3c:0b:59:d2:b9:36 IEEE 802.11: disassociated
Wed Oct 7 04:26:09 2026 kern.err kernel: [43718.191795]
Wed Oct 7 04:26:09 2026 kern.err kernel: [43718.191795] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :3c:0b:59:d2:b9:36
Wed Oct 7 04:26:23 2026 kern.err kernel: [43732.567540]
Wed Oct 7 04:26:23 2026 kern.err kernel: [43732.567540] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :3c:0b:59:d2:b4:50
Wed Oct 7 04:26:26 2026 kern.err kernel: [43735.055464]
Is this a known firmware/driver issue? Any recommended firmware version or
setting to fix it?
Those messages do not by themselves confirm a firmware bug. “Excessive retries” means the AP could no longer deliver frames to that station; it can result from interference, weak signal, client power-saving behavior, or wireless-driver state. The dms not-supported association message may be separate and is not enough to identify the cause.
Please provide the exact firmware version and hardware revision shown under System → Overview; this determines which firmware branch applies. If it is not the latest stable release offered under System → Upgrade, upgrade and test again.
If MLO Wi‑Fi is enabled, temporarily disable it and connect clients only to the regular 2.4/5 GHz SSIDs. If the simultaneous drops stop, that isolates the MLO path; if they continue across the three regular radios, MLO is unlikely to be responsible.
At the next event, before rebooting, export the complete log from System → Log and note the exact time. Send the export privately to a GL.iNet support member or support@gl-inet.com, because full logs can contain network identifiers. The surrounding entries are needed to determine whether a radio/driver restart preceded the retry failures.
I have been experiencing intermittent Wi‑Fi disconnections since purchasing this router. While using my notebook with a full Wi‑Fi signal, the wireless network suddenly disappears and all devices connected to the network are disconnected at the same time.
The issue affects every device on the network, not just a single computer. There are no microwaves or other sources of interference near the router. Before purchasing this router, I used a different router in the exact same location and never experienced these problems.
The disconnections occur randomly, typically once or twice per day. Based on my testing, the issue appears to be related to the router itself.
The OpenWrt build and kernel version do not identify the GL.iNet firmware release. Please provide the GL.iNet firmware version and hardware revision shown under System → Overview (for example, 4.x.x and GL-BE9300/GL-BE9300-R2), and confirm whether MLO Wi‑Fi is enabled. These details determine which firmware branch and known mitigations apply.
At the next disconnection, before rebooting, check whether the router’s uptime resets and whether its admin panel remains reachable over Ethernet. Also note whether every SSID disappears or only one band. Unchanged uptime with wired access still working would isolate the problem to the wireless subsystem; reset uptime or loss of wired access would indicate a broader router restart. Export System → Log immediately afterward and send the full file privately to a GL.iNet support member or support@gl-inet.com, referencing this topic.
The wired connection remains stable and is not affected during these incidents. Only the Wi‑Fi network is impacted, and MLO (Multi‑Link Operation) Wi‑Fi is disabled.
hi, I'm having the exact same issues with the exact same router. same error, same problem with wifi clients disconnecting after mass auths/diss. wired ethernet clients are all fine. it's been driving me insane for around two weeks as i've been trying to figure it out, i've tried different vlans, making new vlans, setting static leases, so forth. the flint 3 is also exactly where my previous router was which had no issues, and is also the same spot my wireless routers have sat for the past 20 years or so. the closest microwave is about 20 to 25 feet away. nearby electronics would include a desktop pc, wireless printer, cable modem, and a cyberpower ups (and the flint 3). i've been having the issue since i plugged the flint 3 in just a short while ago as a recent storm took out both my modem and router together in one shot so i lost an expensive orbi setup and had to buy another cable modem. had recently switched to cable and i did not have the cable routed through surge protection, expensive lesson learned. anyway, i've tried turning everything on, everything off, one item at a time across the wireless vlans in luci hoping maybe i just didn't have some option checked (or unchecked), but nothing made a difference. most notably this is effecting all of my iot security devices, eufy stuff. i had a netgear router i tried to use as an AP which is going through a DHCP (DHCPDISCOVER -> OFFER -> REQUEST -> ACK) doom cycle every 2 minutes re-leasing it's IP over and over again as I tried to use the AP to house the eufy stuff to stop all the disconnects/kicks only to have the same problem but with different symptoms happen to the AP. i should note that i had given it a dhcp static lease and that was set to 12 hours (default) and it was obtaining the correct lease. whether these two issues are related to one another is beyond my skill in the networking arena.
GL.iNet GL-BE9300
ARMv8 Processor rev 4
4.10.1-release
i do have a GL-AXT1800 in AP mode (hard wired, cat5 through lower to upper portion of home but only in 2 places), providing two ethernet ports for desktop pc's well beyond wifi reach. i have a Slate 7 i was going to use for Flint 3 mesh wifi but if I can't get my 2.4ghz security stuff going i'm going to have to find a different main router or some other solution maybe a cheap wifi AP that doesn't drop the connection, open to suggestions, lol.
edit: the only other wifi I'm running is on the 5GHz band on br-guest. the following settings are presently applied as requested but so far i'm not seeing any meaningful difference, i will report back if i do. oh, and unlike OP i do not see and of the two SSIDs drop out. br-iot and br-guest SSIDs remain accessible.
For the Wi-Fi disconnections, could you try setting the Flint 3’s 2.4 GHz Wi-Fi mode to 802.11n/g using the following commands via SSH, and check whether the connection improves?
uci set wireless.wifi0.hwmode='11ng'
uci commit wireless
/etc/init.d/network restart
These commands will briefly interrupt network connectivity, so please run them over a wired connection.
Regarding the Netgear AP periodically requesting an IP address, could you please export the Flint 3’s system logs after it happens, then share them with us via private message along with the AP’s MAC address and the approximate time of the event?
Same issue here on a GL-BE6500, firmware 4.9.0, MLO off, 5 GHz ch 36 / 80 MHz already. “station kicked out due to excessive retries” on wlan1 several times an hour (76 between 1 and 3 Nov), mostly Pixel 9 Pro XL and Pixel 9a. When it gets bad, clients can’t rejoin: hostapd sends 4-way handshake 3/4 repeatedly with no reply and wlan1 drops to 0 clients, while 2.4 GHz is fine. A wifi restart didn’t help; a full reboot helped for ~4 days once, then not at all. I’ve turned 5 GHz off and moved phones to separate APs for now. Happy to send logs by PM.
I had a somewhat similar experience on my Flint 3 with devices dropping or behaving erratically, but in my case the root cause was not the Wi-Fi driver itself. It was the DHCP gateway on the VLAN/Subnet configuration.
In the GL.iNet UI, the “Gateway” field for the subnets was left as “Optional” and that was the issue. Clients were getting correct IPs and DNS, even the correct gateway, but they were losing a ton of packets, they kept timing out and reconnecting, which looked like Wi-Fi instability.
Fix that worked for me:
Go to the DHCP settings for each VLAN/Subnet.
Set the (Optional) Gateway explicitly to the router IP for that subnet (e.g. 192.168.8.1 for the main LAN, 192.168.10.1 for IoT, etc.).
Save/Apply, then renew DHCP leases on clients.
As soon as I made that change, not one dropped packet anymore.
If your clients associate but lose connectivity or keep retrying, it’s worth checking this. It may not be the same as the “excessive retries” driver issue, but it’s a quick check.
P.S. Not sure if this caused the issue, but I changed the VLANs IPs to Main: 192.168.0.1, Guest: 192.168.10.1 and IoT: 192.168.20.1
Thanks for looking into things. I haven't seen a device get the excessive retries notice since making that change but I'm not certain the problematic ones (Eufy specifically), have even been able to re-connect to the wifi since making the change. Here is a longer logfile, pardon the mess there appears to be several things going on here at once. Hermes anonymized any sensitive data in the logfile and was instructed to maintain consistency with the anonymization to allow problematic devices to still be tracked. Hope this helps.
root@router:~# uci show wireless | grep wireless.wifi0.hw
Thu Nov 5 08:30:11 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:30:11 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:31:00 2026 cron.err crond[10698]: USER root pid 7042 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:31:16 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:31:16 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:31:23 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:31:31 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:32 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:33 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:34 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:35 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:36 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:37 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:31:37 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:32:00 2026 cron.err crond[10698]: USER root pid 7600 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:32:02 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:03 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:04 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:05 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:06 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:07 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:08 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:08 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:32:12 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:13 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:14 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:15 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:16 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:17 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:18 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:32:18 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:32:21 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:32:21 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:33:00 2026 cron.err crond[10698]: USER root pid 8143 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:33:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: sending 1/2 msg of Group Key Handshake
Thu Nov 5 08:33:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: sending 1/2 msg of Group Key Handshake
Thu Nov 5 08:33:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: received EAPOL-Key frame (2/2 Group)
Thu Nov 5 08:33:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: group key handshake completed (RSN)
Thu Nov 5 08:33:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: received EAPOL-Key frame (2/2 Group)
Thu Nov 5 08:33:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: group key handshake completed (RSN)
Thu Nov 5 08:33:25 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:33:25 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:34:00 2026 cron.err crond[10698]: USER root pid 8707 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:34:29 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:34:29 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:34:30 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:34:30 2026 kern.err kernel: [156171.553693] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :02:46:9c:7a:cf:d6
Thu Nov 5 08:34:35 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:34:38 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:34:38 2026 kern.err kernel: [156180.026991] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :02:46:9c:7a:cf:d6
Thu Nov 5 08:34:44 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:34:56 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:34:57 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:34:58 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:34:59 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:00 2026 cron.err crond[10698]: USER root pid 9271 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:35:00 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:01 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:02 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:03 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:35:07 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:08 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:09 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:10 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:11 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:12 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:13 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:35:13 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:35:33 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:35:33 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:36:00 2026 cron.err crond[10698]: USER root pid 9807 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:36:11 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:36:12 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:36:13 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:36:14 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:36:14 2026 kern.err kernel: [156276.187642] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :02:46:9c:7a:cf:d6
Thu Nov 5 08:36:17 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:36:36 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:36:36 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:36:57 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:36:58 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:36:59 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:37:00 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:37:00 2026 cron.err crond[10698]: USER root pid 10379 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:37:01 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:37:02 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:37:03 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:37:03 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:37:40 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:37:40 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:38:00 2026 cron.err crond[10698]: USER root pid 10920 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:38:44 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:38:44 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:39:00 2026 cron.err crond[10698]: USER root pid 11481 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:39:49 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:39:49 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:40:00 2026 cron.err crond[10698]: USER root pid 12037 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:40:53 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:40:53 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:41:00 2026 cron.err crond[10698]: USER root pid 12580 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:41:58 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:41:58 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:42:00 2026 cron.err crond[10698]: USER root pid 13135 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:43:00 2026 cron.err crond[10698]: USER root pid 13678 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:43:02 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:43:02 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:43:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: sending 1/2 msg of Group Key Handshake
Thu Nov 5 08:43:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: sending 1/2 msg of Group Key Handshake
Thu Nov 5 08:43:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: received EAPOL-Key frame (2/2 Group)
Thu Nov 5 08:43:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: group key handshake completed (RSN)
Thu Nov 5 08:43:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: received EAPOL-Key frame (2/2 Group)
Thu Nov 5 08:43:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: group key handshake completed (RSN)
Thu Nov 5 08:44:00 2026 cron.err crond[10698]: USER root pid 14233 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:44:06 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:44:06 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:45:00 2026 cron.err crond[10698]: USER root pid 14793 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:45:10 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:45:10 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:46:00 2026 cron.err crond[10698]: USER root pid 15332 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:46:14 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:46:14 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:47:00 2026 cron.err crond[10698]: USER root pid 15891 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:47:18 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:47:18 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:48:00 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:00 2026 cron.err crond[10698]: USER root pid 16443 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:48:01 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:02 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:03 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:04 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:05 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:06 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:48:06 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:48:23 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:48:23 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:49:00 2026 cron.err crond[10698]: USER root pid 16986 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:49:26 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:49:26 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:50:00 2026 cron.err crond[10698]: USER root pid 17541 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:50:29 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:50:29 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:51:00 2026 cron.err crond[10698]: USER root pid 18086 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:51:34 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:51:34 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:52:00 2026 cron.err crond[10698]: USER root pid 18642 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:52:37 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:52:37 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:53:00 2026 cron.err crond[10698]: USER root pid 19202 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:53:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: sending 1/2 msg of Group Key Handshake
Thu Nov 5 08:53:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: sending 1/2 msg of Group Key Handshake
Thu Nov 5 08:53:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: received EAPOL-Key frame (2/2 Group)
Thu Nov 5 08:53:06 2026 daemon.info hostapd: wlan06: STA 02:68:4b:e3:db:d6 WPA: group key handshake completed (RSN)
Thu Nov 5 08:53:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: received EAPOL-Key frame (2/2 Group)
Thu Nov 5 08:53:06 2026 daemon.info hostapd: wlan06: STA 02:35:0b:71:06:db WPA: group key handshake completed (RSN)
Thu Nov 5 08:53:18 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:19 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:20 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:21 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:22 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:23 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:24 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:24 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:53:30 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:31 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:32 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:33 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:34 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:35 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:36 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: authenticated
Thu Nov 5 08:53:36 2026 daemon.info hostapd: wlan06: STA 02:46:9c:7a:cf:d6 IEEE 802.11: disassociated
Thu Nov 5 08:53:42 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:53:42 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:54:00 2026 cron.err crond[10698]: USER root pid 19739 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:54:45 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:54:45 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:55:00 2026 cron.err crond[10698]: USER root pid 20299 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Thu Nov 5 08:55:40 2026 daemon.notice netifd: wan (4408): udhcpc: sending renew to server 68.68.68.68
Thu Nov 5 08:55:40 2026 daemon.notice netifd: wan (4408): udhcpc: lease of 69.69.69.69 obtained from 68.68.68.68, lease time 3600
Thu Nov 5 08:55:40 2026 user.notice kmwan: config json str={ "op": 6, "data": { } }
Thu Nov 5 08:55:41 2026 user.notice firewall: Reloading firewall due to ifupdate of wan (eth0)
Thu Nov 5 08:55:50 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.8.102 02:69:56:1a:d5:54
Thu Nov 5 08:55:50 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.8.102 02:69:56:1a:d5:54 host-a
Thu Nov 5 08:56:00 2026 cron.err crond[10698]: USER root pid 21567 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Could you help to perform the following comparison test?
With the current 5 GHz Wi-Fi settings, try connecting one of the affected Pixel phones and note whether it connects successfully.
Change the 5 GHz security mode to WPA2-PSK (AES), then forget the network on the phone and reconnect to check whether this improves the connection.
After testing, please export the router’s system logs before rebooting and send them to us via private message, including the approximate time of each attempt and the phone’s Wi-Fi MAC address used during the tests.
When the issue occurs, do other devices, also have trouble connecting to the same 5 GHz network?
02:46:9c:7a:cf:d6 is a eufy device (one of three causing issues). See eufy below.
02:69:56:1a:d5:54 is actually a laptop. See Asus below.
eufy devices -- It is specifically three eufy devices, our doorbell, our basement door smart lock, and another lock on a side door in our garage. I believe the noisiest one is one of the door locks but I'm unsure which, largely because anytime I try to view our video doorbell it doesn't complain about being offline and if it is offline it won't work at all. The door locks on the other hand will work when offline and only need to ping the app once in a while to report as online. I can take one of them apart when I get some time so I can figure out which one is which, or I'll block one briefly from logging in and see which one goes offline after an hour or two. Specifically the devices are a C210 Smart Lock and a C33 Smart Lock. The doorbell is a E340.
Asus -- At the time it was spamming DHCP I was presently in the middle of installing Gentoo Linux. After the install was completed I have not seen the DHCP spamming from the laptop since. This could be due to the Gentoo LiveUSB installer containing it's own DHCP client, and installing Gentoo Linux is a little bit more involved then most other linux distributions wherein one builds the entire OS from a chrooted environment compiling what they need from source with gcc/rust and configuring as they go along which would have included, nearing the end of the installation, a DHCP client within the chroot environment. So I'm guessing in this instance the two DHCP clients were fighting the Flint 3 DHCP server for priority to the static lease I had already assigned the Asus before I had begun the installation of Gentoo.
Netgear AP -- I removed the Netgear Orbi AP and the wireless satellites as it couldn't be used at all, and caused a lot of issues on the network. I am not entirely convinced those issues were all the Flint 3's fault. At one point despite the Netgear Orbi being in AP mode it still attempted to grab router IP addresses (eg, 192.168.1.1) that were not being assigned to it by the Flint's DHCP which would have assigned it an address in a completely different subnet. I immediately disconnected it from the network after that. I'm not entirely sure who's to blame here, the Flint, or the Orbi, the Orbi acts like a deprived degenerate gambler with a promiscuous attitude when connected to the Flint in the Orbi's AP mode, but when the Orbi is in router mode on a 5G Mobile Hotspot I have it's perfectly fine. Netgear might just have their underwear all tied up in knots when the Orbi goes into AP mode because then they can't play hide the salami inside the Orbi's SSH access point anymore. That was the whole reason why I wanted the Orbi in AP mode anyway. No means no, Netgear. #metoo.
After applying your suggestion, the device I have named eufy1 on the Flint 3 is no longer able to connect at all really. It does, for a few seconds, and goes off again, just long enough to sort of ping the app and say it's online but that's not normal behavior for the device. The devices haven't been getting kicked for excessive retries but it still spams the logfile. However between your suggestion with the mode and @Eruannon 's suggestion the spamming has nearly stopped... but sadly I think that's because the device is just no longer trying to connect as much as it had frequently. When it does, it still spams, but gives up a lot quicker then before. I have never seen it in the clients list as connected since making the mode change (this would be eufy1). eufy's main product the 'Homebase' stuff, doesn't seem affected. The Homebase 3 connects and stays connected just fine and the majority of things with eufy connect directly to the Homebase, so these issues seem to be isolated to just their standalone products with some worse then others.
If there's anything else I can provide please let me know.
Mon Nov 9 06:17:17 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:17:17 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: disassociated
Mon Nov 9 06:17:21 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:17:21 2026 kern.err kernel: [493540.677851] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :eufy1:mac:address
Mon Nov 9 06:17:27 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: disassociated
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:17:31 2026 kern.err kernel: [493550.829682] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta :eufy1:mac:address
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: associated (aid 4)
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address WPA: sending 1/4 msg of 4-Way Handshake
Mon Nov 9 06:17:31 2026 kern.err kernel: [493550.834184] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address WPA: received EAPOL-Key frame (2/4 Pairwise)
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address WPA: sending 3/4 msg of 4-Way Handshake
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address WPA: received EAPOL-Key frame (4/4 Pairwise)
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address RADIUS: starting accounting session 2CC48EEE300402D4
Mon Nov 9 06:17:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address WPA: pairwise key handshake completed (RSN)
Mon Nov 9 06:17:31 2026 daemon.info dnsmasq-dhcp[1]: DHCPDISCOVER(br-iot) eufy1:mac:address
Mon Nov 9 06:17:31 2026 daemon.info dnsmasq-dhcp[1]: DHCPOFFER(br-iot) 192.168.10.101 eufy1:mac:address
Mon Nov 9 06:17:31 2026 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-iot) 192.168.10.101 eufy1:mac:address
Mon Nov 9 06:17:31 2026 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-iot) 192.168.10.101 eufy1:mac:address eufy1
Mon Nov 9 06:18:00 2026 cron.err crond[10698]: USER root pid 23890 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 9 06:19:00 2026 cron.err crond[10698]: USER root pid 24433 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 9 06:20:00 2026 cron.err crond[10698]: USER root pid 24953 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 9 06:20:26 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: disassociated
Mon Nov 9 06:20:55 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:20:56 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:20:57 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:20:58 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:20:59 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:00 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:00 2026 cron.err crond[10698]: USER root pid 25499 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 9 06:21:01 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:01 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: disassociated
Mon Nov 9 06:21:30 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:31 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:32 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:33 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:34 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:35 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:36 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: authenticated
Mon Nov 9 06:21:36 2026 daemon.info hostapd: wlan06: STA eufy1:mac:address IEEE 802.11: disassociated
Mon Nov 9 06:22:00 2026 cron.err crond[10698]: USER root pid 26016 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Mon Nov 9 06:23:00 2026 cron.err crond[10698]: USER root pid 26556 cmd . /lib/functions/mptun.sh; get_arp_scan_ret
Kernel Log
[451285.367902] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[451639.453933] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy1:mac:address
[451639.453933]
[451639.461232] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[462399.242634] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy1:mac:address
[462399.242634]
[462399.247497] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[463898.021620] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy3:mac:address
[463898.021620]
[463898.027750] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[473540.743036] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy1:mac:address
[473540.743036]
[473540.748944] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[473863.374441] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy1:mac:address
[473863.374441]
[473863.379337] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[484957.044363] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy3:mac:address
[484957.044363]
[484957.051026] wlan: [8413:I:ANY] wlan_cfg80211_change_station: Ignore set station for ap vlan wlan06
[493540.677851] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy1:mac:address
[493540.677851]
[493550.829682] wlan: [0:E:ANY] ieee80211_recv_asreq: ieee80211_recv_asreq: assoc req from dms not-supported sta eufy1:mac:address
I have had 5ghz off since I reported my issues however I wil utrn it back on and carry out the testing later this week and report back. All our mobiles are pixel devices, a 7, two 9a's and a 9 pro xl and all have had the same issues. These are the only devices using the 5ghz network, the rest of my network is wired or on 2.4ghz.
