Hello, Newbie here.
Just got a GL BE9300 wifi7 and I want to configure to nordvpn if possible.
Nordvpn said they do not support routers - only their windows app, so they are of no help.
Would step by step instructions please
Hello, Newbie here.
Please refer to:
NordVPN OpenVPN Configuration Guide: OpenVPN Client - GL.iNet Router Docs 4
NordVPN WireGuard Configuration Guide: WireGuard Client - GL.iNet Router Docs 4
Thank you.
The router say it is wiregaurd but i do not know if nordvpn is providing wiregaurd on their end.
Any newbie way to verify same ?
They provide WireGuard but not for easy usage. Best for newbies is to use OpenVPN.
If you feel advanced enough, you can get the WireGuard configs here: https://nordvpn-config.admon.me
I have done the wireguard installation and it is working.
I however want to confirm that it is actually working.
The router say it has wireguard working.
Don’t know if it is working on nordvpn side.
I want to confirm that it is actually working on both sides
Visit https://ifconfig.co and check if it shows your IP or the NordVPN one.
Yes this shows nordvpn ip.
I am looking to confirm the protocol using on nordvpn side (open vpn or wireguard or other ?)
My side router is showing wireguard
If your router shows Wireguard, it's Wireguard.
ok thanks
