GL-E5800 Mudi 7, 2.4 GHz SSID disappears while access point remains enabled
Hi GL.iNet team,
I'm experiencing a persistent issue with my Mudi 7 (GL-E5800) where the 2.4 GHz Wi-Fi network periodically disappears completely. It cannot be detected by either my Mac or iPhone, while the 5 GHz network continues working normally.
The interesting part: Simply disabling and re-enabling the 2.4 GHz Wi-Fi through the admin interface immediately restores the SSID. However, after some time (sometimes less than an hour), it disappears again.
Device and firmware
  • Model: GL-E5800 (Mudi 7)
  • Firmware: 4.10.2 (1002release)
  • Firmware build date: 2026-11-02
  • Internet: Ethernet WAN primary, cellular backup
  • 5 GHz: Working normally throughout
Current 2.4 GHz configuration
  • Security: WPA2-PSK
  • Wi-Fi Mode: 11b/g/n/ax/be
  • Channel: 1 (also tested channel 6)
  • Bandwidth: 20 MHz
  • TX Power: Max
  • SSID Visibility: Shown
  • Randomized BSSID: Disabled
Troubleshooting already completed
  1. Tested different 2.4 GHz channels and Wi-Fi modes.
  2. Confirmed that the SSID disappears from multiple devices, not just one client.
  3. Set Wi-Fi Idle Timeout to Never.
  4. Disabled Auto System Standby.
  5. Disconnected cellular connectivity to test possible interference.
  6. Verified that the latest available firmware is installed according to Online Upgrade.
  7. Confirmed that toggling 2.4 GHz off and on temporarily restores normal functionality.
None of these changes has permanently resolved the issue.
(I've also sent a message to support but thought I'd ask here as well)
  1. Is this a known issue with the GL-E5800's 2.4 GHz wireless firmware or driver?
  2. Could the repeated AVOID_FREQUENCIES notifications be related to the disappearing SSID?
  3. Is there a newer firmware build or driver fix that addresses this behaviour?
I'm really worried it's a hardware issue :frowning: I'm currently using the device in my office as my main router but all my IOT devices and lights are becoming a nightmare to manage.
Thank you for your question.
We noticed that you have already reached out to us by email regarding this issue.
Please continue working with our support team through the ticket system so we can assist you more effectively.
This post will remain open in case other users wish to share additional suggestions.
Thank you! Yes, the team reached out and supplied me with some BETA software that seems to have solved the problem. My connection to the 2.4ghz has been stable for the last 2-3 hours.
I will continue testing and monitoring, but I'm feeling very optimistic. :smiley:
Hello everyone,
I’m experiencing exactly the same issue with my GL.iNet Mudi 7 (GL-E5800), running firmware 4.10.4.
The 2.4 GHz Wi-Fi network randomly disappears completely and is no longer detectable by any of my devices, while 5 GHz continues to work normally. Disabling and re-enabling the 2.4 GHz band temporarily restores it, but the issue eventually returns.
I’ve noticed that a beta firmware has apparently already been mentioned in the forum, but it hasn’t been shared publicly yet.
Would it be possible to provide me with access to this beta firmware for testing?
I’d be happy to test it and report back whether it resolves the 2.4 GHz Wi-Fi issue.
Since multiple Mudi 7 users appear to be experiencing the same problem, I would really appreciate a potential fix.
Thank you for your support!
I’ve sent the beta firmware via private message. Please check.
We're preparing to include the fix in a beta or stable firmware release, but this may take some time.
Thank you for your patience.
Hi everyone,
First of all, thank you to the GL.iNet team for providing me with the beta firmware to investigate this issue. I really appreciate your support and efforts!
Unfortunately, after testing the beta firmware, the problem is still occurring.
The symptoms are as follows:
  • The 2.4 GHz Wi-Fi network periodically becomes completely unavailable or stops responding.
  • The 5 GHz network continues working normally.
  • Sometimes the connection is interrupted for a few seconds before suddenly recovering.
  • Disabling and re-enabling the 2.4 GHz radio through the admin interface immediately restores normal operation.
  • The issue returns after some time, sometimes within less than an hour.
I have also inspected the system logs and found several recurring Qualcomm WLAN driver messages, including:
  • dp_peer_update_state: Invalid state shift from 2 to 4
  • ucfg_dp_update_dhcp_state_on_disassoc: Peer object not found
  • hdd_son_deliver_peer_authorize_event: ALD ASSOCIATED Event failed
These messages appear repeatedly in the logs. I cannot confirm whether they are directly responsible for the Wi-Fi interruptions, but they might be worth investigating.
Could the development team please investigate whether this might be related to the Qualcomm Wi-Fi driver, particularly its peer management or radio handling?
I would be happy to provide additional system logs or perform further tests if needed.
Thank you again for your continued support!
