GL-E5800 / Mudi 7 cannot activate data connection with Orange Romania SIM
I am having an issue with my GL.iNet Mudi 7 / GL-E5800 using a physical Orange Romania SIM card.
The SIM card is detected correctly by the router, but the cellular data connection cannot be established.
Device details:
Model: GL-E5800 / Mudi 7
Firmware: 4.8.3
OpenWrt base: 23.05.4
Target: sdx75/generic
Modem: Quectel RG650V-EU
Modem firmware: QRM650VEU00ADR02A04G8G_OCPU_RGH_01.005.01.005
Operator: Orange Romania
APN: net
Authentication: NONE
Protocol: rmnet
Network Type: Auto
Band Masking: Disabled
The SIM is detected correctly:
ICCID: 8940102407180580063F
IMSI: 226101500921981
MCC/MNC: 226 / 10
The modem also appears to register on Orange LTE:
AT+COPS?
+COPS: 0,0,"orange",7
AT+CEREG?
+CEREG: 0,1
AT+CGATT?
+CGATT: 1
However, the data connection fails. In the GL.iNet interface it remains stuck on “orange Connecting...” or fails with:
Failed to set context status
callcode: 28689
From the debug logs:
CGACT: 1,0
QIGETERROR: 561, activate pdp context failed
I also noticed that the modem initially selected this MBN profile:
France-Commercial-Orange
This seems suspicious because the SIM is Orange Romania, not Orange France.
I manually disabled MBN AutoSel and selected:
ROW_Commercial
using the AT port directly, because the GL.iNet AT wrapper sometimes returned mixed/stale responses.
After selecting ROW_Commercial, the MBN list showed:
France-Commercial-Orange: 0,0
ROW_Commercial: 1,0
But after restarting the cellular manager, the router started failing with:
Failed to set APN info
callcode: 28682
The APN config for the SIM is still correct:
manual: true
apn: net
auth: NONE
roaming: true
So the issue seems to be related to the GL.iNet cellular manager / Quectel MBN profile handling / PDP context activation, not a simple APN mistake.
I also tested after factory reset and the same issue happens again with the Orange Romania physical SIM.
Can GL.iNet please confirm:
  1. Is Orange Romania supported on GL-E5800 / Mudi 7 with the RG650V-EU modem?
  2. Should the modem use ROW_Commercial instead of France-Commercial-Orange for MCC/MNC 226/10?
  3. Is there a beta firmware or modem firmware update that fixes this issue?
  4. Is “Failed to set APN info” after changing MBN profiles a known bug in firmware 4.8.3?
I can provide the full modem debug logs if needed.
Thank you.
Hello @Ryan87BC I’ve sent you a beta firmware. Please check the message and give it a try
@Cathy
Hello Cathy,
Thank you, I received the beta firmware.
I am currently on vacation and I do not have the router with me, so I cannot test it safely right now.
I will try the beta firmware after I return from vacation, around June 1–2.
Thank you.
There is new firmware v4.8.4: GL.iNet download center. You can can directly upgrade to this firmware to try. For your Orange SIM card, we suggest upgrading without keeping settings :blush:
Hi Cathy,
Thank you.
I already installed the firmware that appeared directly in the router UI, and I upgraded without keeping settings, as recommended.
After the upgrade, the router was reset/clean and I only performed a minimal setup again.
In the router UI I currently see:
Firmware version: 4.8.5
Version: 4.0
Firmware Type: 0805release
Update Time: 2026-06-03 03:18:34 UTC
However, Orange Romania still does not work. It still remains on “orange Connecting...” / “Check SIM card” / no usable cellular data.
The Orange SIM is detected correctly and LTE cell info is visible, but no IPv4 address, gateway, or DNS is obtained for the cellular interface.
Current setup:
Device: GL-E5800 / Mudi 7
Slot 1: Digi Romania, MCC/MNC 226/05, APN internet
Slot 2: Orange Romania, MCC/MNC 226/10, APN net
Digi Romania works only intermittently and usually stays on 4G/LTE. Stable 5G is still missing or unstable.
Orange Romania still does not establish a usable data connection.
Could you please advise what troubleshooting steps I should try next to resolve this issue?
Since the router reports Firmware Type 0805release and the update was installed directly from the router UI, I assume I am already running the latest official firmware available for this device.
At this point, I would appreciate specific guidance on how to make Orange Romania work and how to obtain a stable 5G connection with Digi Romania. If additional logs, modem diagnostics, or AT command outputs are needed, please let me know exactly what information you would like me to provide.
Thank you.
Could you bind your device to Goodcloud and share it to technical support for remote troubleshooting? Here are the instructions. Thank you!
@Cathy
The device is already bound to GoodCloud and shared with GL.iNet Technical Support for remote troubleshooting.
If you need any sensitive information, such as the GoodCloud account, MAC address, or temporary admin password, please contact me privately or through a secure support channel. I do not want to post those details publicly on the forum.
Thank you.
Just found the issue is due to the sim card configuration.
Could you confirm if a factory reset has been performed previously?
If so, could you reset the device again? We would like to investigate whether there is an issue with the default settings.
Thank you for checking.
I performed a factory reset again, this time using the router’s touchscreen menu.
After the factory reset, Orange Romania now seems to establish the data connection, so the issue may indeed have been related to the SIM/card configuration stored by the router.
However, Orange still only connects on 4G/LTE. I still do not get 5G on the GL-E5800, even though the same Orange SIM card gets 5G on my phone in the exact same location.
So the current status is:
  1. After factory reset from the touchscreen menu, Orange data works now.
  2. Orange still only works on 4G/LTE on the router.
  3. 5G is not available on Orange on the GL-E5800, although the same SIM gets 5G on my phone in the same place.
  4. Digi Romania also usually stays on 4G/LTE and 5G is still not stable or predictable.
One more important note: Orange Wi-Fi Calling from my iPhone only works through the router when Network Acceleration is turned OFF. When Network Acceleration is ON, Wi-Fi Calling does not work properly.
Previously, we also observed that Wi-Fi Calling traffic uses UDP 4500/IPsec NAT-T, so it seems Network Acceleration / flow offloading can interfere with Wi-Fi Calling over the router.
Could you please advise why 5G is still not working on Orange Romania on the GL-E5800, despite having 5G coverage and 5G working on the same SIM in my phone?
Thank you.
Quick update for transparency, in case other GL-E5800 / Mudi 7 users with Orange Romania or Digi Romania have the same issue.
GL.iNet support checked the router remotely and said that, according to the module logs, the 5G connection was refused by the cell tower / no 5G network was available for the router. They also said that the router was currently running on 5G.
However, after that message I checked the router myself via SSH and the modem-level AT command output still reports LTE only, not NR/5G.
Current Orange Romania connection from ubus:
mode: LTE FDD
band: 3
ipv4: 10.138.221.236
gateway: 10.138.221.237
dns: 109.166.202.53 / 109.166.202.54
Direct modem output:
AT+QENG="servingcell"
+QENG: "servingcell","NOCONN","LTE","FDD",226,10,46E701,309,1600,3,5,5,277B,-98,-16,-61,11,10,90,-
Carrier aggregation info:
AT+QCAINFO
+QCAINFO: "PCC",1600,100,"LTE BAND 3",1,309,-97,-11,-63,6
Signal query:
AT+QCSQ
+QCSQ: "LTE",-66,-98,8,-12
So at modem level, the GL-E5800 is connected to Orange Romania on LTE Band 3 only. I do not see NR5G, NSA, n78, or any 5G carrier component in the AT output.
This is different from my iPhone in the exact same location with the same Orange Romania SIM card, where Field Test Mode shows Orange 5G NSA on n78 with 100 MHz bandwidth.
So my open questions are:
  1. When the router UI shows “5G”, is that based on real modem NR/NSA status, or only a UI/network capability indicator?
  2. If the router is truly connected to 5G, which AT command confirms the active NR/NSA/n78 connection?
  3. Why do AT+QENG, AT+QCAINFO, and AT+QCSQ still report LTE only?
  4. Why does the same Orange SIM get 5G NSA n78 on iPhone in the same place, while the GL-E5800 remains on LTE?
  5. Will this be fixed in a public firmware update?
There is also a second issue:
Orange Wi-Fi Calling on my iPhone only works through the GL-E5800 when Network Acceleration is OFF. When Network Acceleration is ON, Wi-Fi Calling does not work properly.
Since Wi-Fi Calling uses UDP 4500 / IPsec NAT-T, it looks like Network Acceleration / flow offloading interferes with that traffic.
Could GL.iNet please confirm whether this is a known issue and whether it will be fixed?
There is also a third issue with Orange Romania eSIM:
I cannot install/use an Orange Romania eSIM on this router. The eSIM activation fails with the error:
EID-Blacklist
This should also be clarified, because Orange Romania eSIM works on supported phones, but it does not appear to work on the GL-E5800 / Mudi 7.
Could GL.iNet please confirm clearly:
  1. Is Orange Romania eSIM officially supported on the GL-E5800 / Mudi 7?
  2. If not, is this a GL.iNet limitation, a modem/eSIM implementation limitation, or an Orange Romania carrier restriction?
  3. Can this be fixed by firmware, or is Orange Romania eSIM not supported at all on this device?
At this point, if GL.iNet cannot provide a clear fix or a clear technical explanation, I would like to return the router for a full refund.
The router does not provide stable/working 5G as expected with Orange Romania or Digi Romania, Orange Wi-Fi Calling does not work properly with Network Acceleration enabled, and Orange Romania eSIM cannot be installed due to the EID-Blacklist error.
I no longer have the original box, but the device and accessories are available.
Since the router is not working as expected and the issue has not been resolved, I do not think it is fair for me to pay the return shipping costs. I would like GL.iNet to provide a prepaid return label or otherwise cover the full return shipping cost.
Please confirm if I can return the GL-E5800 / Mudi 7 without the original box, with return shipping paid by GL.iNet, and receive a full refund.
I am posting this here because the technical details may help other users, and I would prefer the root cause and final solution to be visible publicly instead of only discussed by email.
Hello there,
I have the exact same issue with Orange France on my GL-E5800 (Mudi 7) that I received yesterday.
Modem stuck on LTE only. 5G NR never activates despite being available in my area.
Device physically has antennas available for 5G NR (3500 MHz and 700 MHz bands).
Another 5G router (NETGEAR Nighthawk M6 Pro) with same SIM works perfectly in same location.
Same Orange France SIM works on 4G LTE Band 20 in the Mudi 7.
Device Information :
  • Device : GL-E5800 (Mudi 7)
  • Modem : Quectel RG650V-EU
  • Modem Firmware : QRM650VEU00ADR02A04G8G_OCPU_RGH_01.005.01.005
  • GL.iNet Firmware : Tested 4.8.1 through 4.8.5 (clean flashes)
  • SIM : Orange France
AT Command Results :
  • +QNWINFO: "FDD LTE","20801","LTE BAND 1",524
  • +COPS: 0,0,"Orange F",7
  • +C5GREG: 0,0
Let me know if you need more details.
Thanks
Hello, this is a different issue. As a test, please navigate to the NETWORK ->Multi-WAN->Cellular settings, change the cellular detection mode to strict or normal mode and try again.
If no luck, please help check the cell info of the NETGEAR router, including the cell id, bands, etc
Thanks
Same issue for me…
Orange PL Of course there are problems with 5g, the installed beta 4 version does not improve anything.
Hello, thanks for reporting the issue.
Can you connect to 5G when using the same sim card on another device?
To help us better analysis, could you share device to support through Goodcloud from troubleshooting, as per: Technical Support via GoodCloud - GL.iNet Router Docs 4
Alternatively, could you help check the following information:
  1. Insert the sim card on the phone to check the 5G cell info, including cell ID, band, PCI, etc.
  2. Plug in the sim card to the Mudi 7, navigate to the NETWORK >Multi-WAN, set cellular interface detection mode to normal or strict mode.
  3. Log in to the Mudi 7‘s ssh, enter the command below:
    Cellular_debug.sh 1
    Then enter the command below to check the network environment:
    gl_modem -B cpu -U 1 AT AT+QENG=\"servingcell\"
    gl_modem -B cpu -U 1 AT AT+QSCAN=3,1
    Pls note: if you use SIM2 or eSIM, please use command gl_modem -B cpu -U 2 xxx instead.
  4. enter the following command to stop the cellular debug process.
    Cellular_debug.sh 0
Please export the /tmp/cellular_manager.log from the Mudi 7 via scp, along with the cell info and AT command results from step 3, for our analysis. Thanks
