I found an issue with SIM card management: even if failover is switched OFF and esim in use, SIM1 is always logged on (or trying) to network. When travelling across multiple countries it’s bit annoying when you receive unneccessary text messages, especially if SIM card doesn’t have or have limited roaming.
It would be really useful if there is an option to completely disable any SIM1 activity if not used and load balancing/failover not in use.
Entire SIM/eSIM management could be little bit easier or less cluttered, but I can live with that. Having proper ON/OFF control over sim cards appears to be far more important
Thanks
