What is the maximum size for the attached drive on MUDI? I am getting the name of the 2 Tb SSD under the GL-Samba but the folder is empty. MUDI works OK with 1 TB SSD attached (same brand SanDisk). The 2 TB SSD folders and files are visible on GL-AR750S. Both routers are running on the 3.125 firmware.
Thanks
The largest drive we have tested on the E750 is 1TB. But I think this may have something to do with the drive type and disk format.
The drive is the same SanDisk only double capacity, I will try to play with the format …
The only reason for the post is that both drives are working on AR750S without any problems…
