My Mudi (running version 3215 / 3216) is connected to the hotspot which is shared by my Iphone14pro.
Unfortunately the WWW is not reachable when using the hotspot as gateway.
Other devices which connects directly to the hotspot of the iPhone works properly.
Do you have any idea what the reason can be?
I have tested this with an other iPhone which runs with iOS15.7 at the moment. This is working correctly. So it seems to be an iOS16 issue.
I learn that it fails occasionally, and more related to ios issue, could you try restarting your iPhone or turning off and on the hotspot and see if it works?
thank you for your reply. Actually I have already done this a few times in the past without success.
Just to clearify, the internal communication between devices which are connected to the WIFI of the MUDI works properly. The issue is only the WAN-OUT. It is not possible to reach the internet, although the iphone14pro which provides the hotspot, displays that a device is connect to the hotpot.
Do you need further logfiles or stuff to find out what the reason could be?
It looks like the iPhone only assigns ipv6 addresses to clients which are connected to the hotspot. Maybe this can be a reason. As I told you before, the issue happen via wifi as well as cable tethering USB connection.
633.631161] usb 1-1.3: new high-speed USB device number 5 using ehci-platform
[ 633.798977] ipheth 1-1.3:4.2: Apple iPhone USB Ethernet device attached
[ 678.501566] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 678.508633] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 680.111790] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
during the meantime I was able to solve the issue.
I have reset the iPhone network configuration and abvoisly this could solve the problem with this error.
