Hi.
I have “EC25-E Mudi (GL-E750) 4G LTE”
My mudi constantly lowering the signal.
Example:
- with SIM card in my phone I have 124 Mbps
- with the same SIM card in Mudi and then connect my phone to Mudi I have 15 Mbps
Same situation when Mudi is repeater, then wifi signal is also lower.
Why my Mudi such lower signal ?
I don’t use VPN. I don’t use TOR. Only 1 device connected at time. Signal is testing with the same conditions, at low traffic (5 AM). Tested on 2.4 GHz and 5 GHz. I also checked with maximum and minimum speed and TX Power (dBm) in admin panel.
This is not one situation, My mudi constantly lowering the signal even on other devices. Do you know Why ? is there somewhere some hidden settings ?
