Hi all,
I’ve been using the router for 2 weeks now on a daily basis and here’s a couple of issues and cons I found out
- the 5GHz antenna is totally useless. It breaks internet and can’t keep up the connection for over 1 client
- mount and share management is atrocious tragic. The router doesn’t see the external portable hard drive even if according to the documentation (File Sharing - GL.iNet Docs). Accessing the SD card in the router is also painful. This is not a file hub as there’s no file management at all
- Will the battery survive if the router is constantly connected to a wall USB charger?
Everything else works as intended.
Thanks
