After the latest firmware V3.203 I can not log into Luci, I tried to install Luci again and I get an error, who knows the solution.
Maybe you can get a pc and ssh to the router to reinstall luci.
opkg update
opkg install --force-reinstall luci
Cannot really see the actual error in the video. But seems some packages failed to install.
Try going to Applications - Plugins and Update from there then try installing from Advanced Menu again.
Seems E750 cannot connect to our server.
Does it has Internet? Or vpn or carrier limitations to access the Internet?
Yes, there is Internet, vpn is not used.
Can you try the following command and give me output?
ifconfig
ping 8.8.8.8
ping google.com
If necessary can I have a remote check using anydesk or teamviewer?
At least https://fw.gl-inet.com/releases/v19.07.7/packages-3.0/ath79/glinet/Packages.gz is downloadable.
Is there anyway that you can think of it is blocked by your carrier?
I don’t know what the problem was, but today everything was established, did you have any maintenance work on the server?
I am not sure. But as you can do it now hope it is solved by now.
