I tried to config OpenVPN client for Express VPN and it does not connect for all servers
I am getting the following error
WARNING: --keysize is DEPRECATED and will be removed in OpenVPN 2.6
OpenVPN 2.5.2 mips-openwrt-linux-gnu [SSL (OpenSSL)] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
library versions: OpenSSL 1.1.1k 25 Mar 2021
neither stdin nor stderr are a tty device and you have neither a controlling tty nor systemd - can’t ask for ‘Enter Auth Username:’. If you used --daemon, you need to use --askpass to make passphrase-protected keys work, and you can not use --auth-nocache.
Exiting due to fatal error
