Just did some testing with my new toy, feels good
What puzzles me for a few hours is that sd card is not writable. What did I do:
- in admin panel under ‘File sharing’ I made sure ‘share via lan’,‘share via wan’, ‘writable’ are all toggled to ‘On’
- I formatted the sd card with an ext4 partition (tried also vfat, no difference)
I ssh’t into the GL-E350 and went to /mnt/sda1. I see all those unreadable empty files, which is done by GL-iNet I presume. I also read files I put on the SD before. But I can’t write any new files or edit existing ones.
I also connected a usb stick to the GL-E350 (also ext4). Here I can do everything I like, especially writing and editing files.
$ ls -l /mnt/*
drwxrwxrwx 41 root root 8192 Jan 1 1970 sda1
drwxrwxrwx 3 root root 4096 Feb 1 02:34 sdb1
What do I miss? Thanks for helping me on.
I also did some fiddling with samba. laptop with linux/ubuntu connected to GL-E350. I no way get any access to ‘file sharing’ on GL-E350. Also not when I connect the share to my usb stick. If anyone has any thoughts I would like it very much.
Thanks, Roger
