GL-E750 V1 and V2 Repeater issue
Repeater mode in both versions of Mudi cannot detect any surrounding network. Both routers need several reboots to detect Wi-Fi signals. When the connection is established, no dropouts are recorded.
May I know what firmware version of them?
Try enable the 'Force 20MHz Bandwidth for 2.4G', wait patiently for it to finish scanning.
The firmware is updated to version 4.3.19. Forcing 20MHz didn’t resolve the issue. I received the message: “Operation timed out. Please check the network environment or reboot the device.” After a few reboots, the repeater started working as expected.
Due to the device performance of E750, may be not fast when scanning WIFI.
Please wait patiently for the scanning to complete before operating.
If issue still occur, please PM me the syslog.
Disabling the 5G wireless network on the E750 allowed the repeater to finish scanning and establish a connection to the WiFi.
I am actually having this exact same problem since the v4 firmware upgrade. I get this error all the time now even when I remove the SIM
Any thoughts?
Syslog shows this over and over
Fri Feb 14 21:04:59 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:00 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:01 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:02 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:03 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:05 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:06 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Fri Feb 14 21:05:07 2025 daemon.err lua: (...6e/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:385) Wait phy ready...
Can you send out the full log?
Is there a way to share it privately not on the public forum? I worry about any inadvertent data leakage.
UPDATE: I sent this as a direct message to your @JerryZhao
Could you show me the wifi config?
cat /etc/config/wireless
Sent through PM
M
Please execute the command and show me the output.
iwinfo
sent through PM
I checked the logs and suspect it's a configuration issue. Can you share the device via goodcloud so I can check the issue remotely?
this has been added to goodcloud. DeviceID sent in direct message
This exact problem is back again a few weeks later. Is there a way to permanently fix this? or provide me with the commands to fix it?
Previously one of your engineers connected and fixed it and it worked for a couple of weeks
The reason for this problem is that when the actual status of the interface is detected to be inconsistent with the configured status, this information will be printed. We are already paying attention to why this problem occurs.
If you want to solve the problem yourself, you can use the command: "ubus call network.wireless status" to check the actual status of the interface. "uci show wireless" to check the configuration information of the interface.
If you find a difference, you can try to recover by executing "wifi" or "/etc/init.d/network restart" to restart the network.
If "uci show wireless" shows missing configuration, you can add it through "uci set xxx=xx", and then execute "wifi" or "/etc/init.d/network restart" to restart the network to make the configuration take effect.
I am still doing this almost every trip (works most time). Is there a fix yet in firmware? If not when is that coming?
Also- I did a factory reset a few weeks ago but the issue is still there even after
Please share your device with technical support through GoodCloud, and I will fix the problem for you through backend modification.
Let me know when this is completed.
Password: sent through private message
Will this fix get wiped out when i update the firmware next?
M
The modification has been completed and will be included in the next firmware update.
