GL-E750 V1 doesn't enter u boot recovery
Hello
I have a problem with gl-e750 (midi v1), it doesn't go into uboot recovery mode.
I was setting up the singbox tunnel and deleting the old configuration with package labeling, I affected the files
/etc/iproute2/rt_tables, /etc/config/network and /etc/config/firewall. After returning these files to their original state before configuring the tunnel, disabling the service and rebooting, the device did not start. I tried to restore it via uboot with the old firmware from v3 wiki and the new firmware (openwrt-*.bin). As a result, the device stopped loading (freezes by 90%), does not enter u-boot mode (when the button is pressed, the countdown does not start to start recovery mode)
I realize that this is an old model, but I did not find any information on it and decided to contact the forum and email technical support for help
Thank you if you take the time and tell me what can be done
Can you confirm it's the GL openwrt firmware and not some firmware directly from the OpenWrt community?
Yes, I took it from the official website dl.gl-inet.com
I would like to make a clarification, now the device responds to the power button even when it is running, but there is no reaction to the reset button pressed when turning on (no reset counting)
