Dear Support Team,
I am contacting you because I have encountered a problem where I can no longer solve the fault myself.
I bought the GL.inet GL-E750 V2 a few weeks ago. I have the problem that I can only connect to the mobile network.
I cannot establish a connection to my Wireguard server. If I deactivate the mobile network and establish a connection
I can connect to the Wireguard server via the repeater. It just doesn't work over the mobile network.
I have reset the GL-750 V2 to factory settings.
I have reinstalled the latest firmware version 4.3.19.
I have installed the beta firmware 4.3.21.
All these attempts have not been able to establish a VPN connection to my Wireguard, it only works via repeaters.
If I deactivate the Wireguard client in the GL-E750 V2, I can connect via the mobile network without any problems.
Can anyone help me?
