Hi all,
I'm having trouble connecting to a WIFI source on my GL-E750 router. Firmware 4.0. The WIFI is password protected and does not have a captive portal. Connection works fine without a VPN connection if just repeating the signal.
I've tried both Wireguard and OpenVPN connections, but they seem to get stuck in yellow ocassionally the connection becomes green but no websites can be accessed. Then it usually drops again.
Any suggestions on what to try?
DNS settings below:
WG log below:
Sat Aug 17 15:39:20 2024 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Aug 17 15:39:31 2024 daemon.notice netifd: Network device 'wgclient' link is up
Sat Aug 17 15:39:31 2024 daemon.notice netifd: Interface 'wgclient' is now up
Sat Aug 17 15:39:44 2024 user.notice wgclient-up: env value:T_J_V_ifname=string J_V_address_external=1 USER=root ifname=wgclient ACTION=KEYPAIR-CREATED N_J_V_address_external=address-external SHLVL=2 J_V_keep=1 HOME=/ HOTPLUG_TYPE=wireguard T_J_V_interface=string J_V_ifname=wgclient T_J_V_link_up=boolean LOGNAME=root DEVICENAME= T_J_V_action=int TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin J_V_interface=wgclient K_J_V= action ifname link_up address_external keep interface J_V_link_up=1 J_V_action=0 T_J_V_address_external=boolean N_J_V_link_up=link-up T_J_V_keep=boolean PWD=/ JSON_CUR=J_V CONFIG_SECTIONS=global AzireVPN Mullvad FromApp group_1506 group_824 group_3791 group_6076 peer_2001 group_9539 peer_2002 group_3067 peer_2003 group_6854 peer_2004
