Hello all,
The router GL-E750 is operated without a SIM card. I only use the WIFI repeater function. There is an OpenVPN configured with killswitch function and AdGuardHome is active. The router works in (router) mode.
The firmware is 3.215.
There are three Wifi SSID from different location configured in the router. When I change the location it does not automatically connect to the wifi from the location. Also the own WIFI hotspot of the E750 is not displayed on the computer.
It seems as if the router does not do a wifi scan or auto connect to known wifi’s in the location.
If I go back to the last working location then the router connects to the wifi and the router’s own wifi is also visible. In between changing the location the router is turned off and on again by me.
Curious solution
If I change to a known location and it does not connect to the wifi network, I can solve the problem by connecting to the E750 router with the LAN adapter and calling the router address in the web browser via LAN connection without logging on to the router website. Then the router finds the wifi, the router automatically connects to the known wifi in the location and the router’s own wifi is also visible on the computer and I can work normally with the router via wifi without LAN cable.
Does anyone have an idea what is the problem? Thanks.
