GL-E750V2 eSIM Profile activation fails
I'm having a problem activating an additional eSIM profile on my Mudi (GL-E750V2). I bought the EIOTClub SIM to eSIM card but when I try to add an additional profile (directly after I add the QR code) it fails with the following error:
Device start connect internet
Connect internet fail: Please make sure that you have set up the Internet interface to use cellular (with esim seed profile), wan cable or repeater to connect to the Internet.
The device has an internet connection via cellular but I tried adding an USB Ethernet Adaper as well, without success. Is there anything I might have missed?
I followed the steps from the official glinet docs from their website. The firmware is up to date. If it helps I can add the exact version later.
After adding LPA: to the activation code (LPA:ACTIVATIONCODE) I was able to add and download the profile. Might be helpful to add this information to the official docs so others who struggle with the problem can find it quicker.
Out of curiosity: Why are there different "standards" for the syntax of the activation code? Or does it have to do with the region of the eSim profile?
Hi @AcidDemon, thank you very much for your information, it is useful!!!!!!
Can you tell your device firmware version and where esim profile do you purchase.
About this esim profile, if you can give me its URL or screenshot about this esim profile or give me your esim QR code, it is best for us to analyse, thank you!
Hi, no problem:
Firmware is 4.0 - 0326release1
and the profile was bought at silent.link but they are only a reseller as far as I know.
But it is working without problems here in Europe and different local providers can be chosen (prices per GB vary, info can be found on their website).
OK, got it, thank you very much! Their QR codes do not fully follow the standards of the eSIM QR codes, we will fix this bug in our new firmware(if the QR code don't have LPA: text, we UI will add it automatically) and we will improve our docs.
