GL-E750V2 Mudi firmware
I have Mudi V2 bought last fall, and tthere is firmware 4.3.28 with date 2025-06-26, i see that on:
GL.iNet download center latest is 4.3.26 date: 2025-04-08, i would like to test beta (4.8.3) but i cannot go revert back to 4.3.28 as this is not available for download… can you please add?
And beta is quite old 2025-09-30 - will be never released?
The v4.3.28 is a factory firmware and does not include any functional changes compared to v4.3.26, so you can simply use v4.3.26.
As for firmware updates for the E750v2, we’re still working on them. The next release may be v4.8.4 beta, there should be still quite a bit of work to be done before a stable version is available.
Good to know!
I was thinking if you don abandon software for Mudi v2 when you released Mudi 7.
It seems actually the opposite. The v2 firmware has been actively advanced even though its processor isn't much more powerful than the Mango and less powerful than the MT1300, probably as a test platform for the 7.
You was right!
Today i see new firmware in Beta section 4.8.4 :slight_smile:
Yes, downloaded and then updated about 14 packages. Seems to be working fine.
beta 4.8.4 incorrectly shows downloaded data via cellular interface.
