bonjour , le routeur est branché sur Ethernet ,j’ai installer les serveurs nordvpn tout fonctionne bien sauf que quelques fois le pc est déconnecter d’internet ,pourtant le vpn est toujours actif dans l’interface du routeur,merci.
hello, the router is connected to ethernet, I installed the nordvpn servers, everything works well except that the pc is disconnected from the internet a few times, yet the vpn is still active in the router interface, thank you.
How far apart are the Internet disconnects and does it reconnect automatically or manually afterward?
Does wifi on the PC gets dropped, or does wifi stay connected but you cannot access the Internet?
hello, the wifi of the pc is disconnected.
the wifi of the router is disconnected.
internet on the pc disconnects a few times but the vpn of the router is still active (green dot).
so I restart the restart of the router to have internet on the pc. the box is ok. the firmware of the router is up to date.
Were you downloading/uploading a lot of data when the disconnects occur? Do you also get the disconnects when the router is not connected to VPN?
If you can see a green dot for VPN in the Admin Panel UI, then it seems you are connected from another PC and the router wifi/VPN are still active, so try reconnecting the PC wifi without rebooting the router.
hello, I reset the router, I put the router on wifi, unplugged ethernet cable and again the pc disconnects from the internet, no, I don’t download anything. as if it were my network card that failed. can be a problem.
You have to log into CyberGhost and download config file from their website.
If you have already tried NordVPN and VPNbook, then the problem may not be with the VPN provider. It may be worthwhile to do a factory reset (“Revert Firmware”) on the router and start fresh.
probleme de connexion avec le vpn cyberghost ou avec un autre,j’ai remis le routeur à l’état usine est pareil , le voyant vert ne se met pas il reste orange,quel est le probleme,merci
