Dear all,
my GL-iNet 6416A v1 says it’s connected to the VPN provider, and obviously it really has some sort of internet connection, because it was able to check for new updates (firmware v2.25 is installed). But the computer that’s connected to the 6416A via patch cable can’t reach the internet. No ping, nothing.
The computer and cable connection are both ok - I can reach the 6416A on 192.168.8.1 and configure it. I just can’t get to the internet through the 6416A. I’ve been tinkering desperately since days, so maybe I spoiled something at some point. It is my understanding that the problem most probably is the bridging between RJ45-LAN and Wifi-WAN. Went back to factory settings a few times already to start from scratch. So, I guess I need some good advice now. Am I missing anything? Any ideas?
The OpenVPN client page states a little data in/out: Data received: 24.66K, Data sent: 19.59K. Both values increase very slowly every few minutes. Maybe some connection stay alive protok0ll.
I tried to ping both domain name (www.google.com) and IP directly (8.8.8.8). It doesn’t say “dns not resolved”. In both cases it says “connect: Network is unreachable”
No, I didn’t upload anything before upgrading. After upgrading I installed macchanger, which I removed right now, then rebooted, but still no connection.
Btw. I tried with and without “Force VPN - No Internet if VPN is not connected”.
Also I tried to connect when VPN was disabled (“Enable” not ticked), without success.
