GL.iNet App Android an eSIM Manage
Hi, setting up the eSIM function on the GL-E750 worked perfectly. I can manage the eSIM via the administrator interface on my PC.
I use the physical esim card from EIOTCLUB (via GL.iNet Store) and also a purchased eSIM from EIOTCLUB.
On the road, however, I can only access the Mudi Rouetre with the GL.iNet app on my Android phone. However, I have not found a section in the app for administering the esim. How can I administer my esim on the Mudi router via the Android app?
Best regards
Can't you just open the browser on your phone to visit the website?
Thank you very much, yes that worked too.
Replicating every function of the web admin panel in the app will be extra cost and sometime not very necessary. So if you can keep using the web admin panel that will be nice.
