Just found out that the gl-inet App has confusing Wi-Fi SSID visibility indication.
My Wi-Fi SSID on Flint is always searchable(open) , however when check with gl-inet App on my Android phone, the status is “OFF” ?? The on/off button with the description beside make people confusing.
On the web GUI, the SSID is set visible: (shown)
On the App, it looks like in the opposite setting: (hidden) (visibility is off = hidden)
Maybe you guys can either adjust the wording or setting to reflect to what the correct setting is …
Thanks !
