I’m trying to understand if there are limitation on these device is that slows down the connection speed.
If I connect directly to my hotel’s wifi it will run at
45 MBPS download, and 47Mbps upload.
I bought 2 GL Inet Travel Router but unable to get the same speed as direct connection.
When I tried the
GL-MT300N-V2 : Version 3.203 - Channel 1
I get Wifi Speed :12 Mbps Download and Mbps 15 Upload
Lan Cable: 45mbps
GL-AR750s-202-5g : Version 3.203 - Channel 48
Wifi Speed: 29mbps download, 36mbps
Lan Cable: 29mbps download, 36 mbps upload
Is this acting normal because of a device in between my computer and the hotel’s internet?.
I’m puzzled on why the MT300N-V2 when the computer is plugged directly in, it runs at full speed but the GL-Ar750s remains the same no matter which way you connect it to.
Any suggestion would be helpful.
Thank you.
