GL-iNet AX1800 OpenWrt firmware
@solidus1983 , with r24114exp , no more crashes but local AP doesn’t come up:
Thu Oct 12 23:27:18 2023 daemon.notice netifd: radio0 (10222): sh: out of range
Thu Oct 12 23:27:18 2023 daemon.notice wpa_supplicant[4767]: Set new config for phy phy0
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: Restart interface for phy phy0
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=HK ieee80211d=1 ieee80211h=1 hw_mode=a beacon_int=100 chanlist=124 noscan=1 tx_queue_data2_burst=2.0 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[HT40+][LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][MAX-AMSDU-7935][DSSS_CCK-40] ieee80211ac=1 vht_oper_chwidth=1 vht_oper_centr_freq_seg0_idx=122 vht_capab=[RXLDPC][SHORT-GI-80][TX-STBC-2BY1][SU-BEAMFORMER][SU-BEAMFORMEE][MU-BEAMFORMER][MU-BEAMFORMEE][RX-ANTENNA-PATTERN][TX-ANTENNA-PATTERN][RX-STBC-1][SOUNDING-DIMENSION-2][BF-ANTENNA-2][MAX-MPDU-11454][MAX-A-MPDU-LEN-EXP7] ieee80211ax=1 he_oper_chwidth=1 he_oper_centr_freq_seg0_idx=122 he_su_beamformer=1 he_su_beamformee=1 he_mu_beamformer=1 he_bss_color=128 he_spr_sr_control=3 he_default_pe_duration=4 he_rts_threshold=1023 he_mu_edca_qos_info_param_count=0 he_mu_edca_qos_info_q_ack=0 he_mu_edca_qos_info_queue_request=0 he_mu_edca_qos_inf
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.794032] br-lan: port 3(phy0-ap0) entered blocking state
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.794084] br-lan: port 3(phy0-ap0) entered disabled state
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.798807] device phy0-ap0 entered promiscuous mode
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: interface state UNINITIALIZED->COUNTRY_UPDATE
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: interface state COUNTRY_UPDATE->DFS
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: DFS-CAC-START freq=5620 chan=124 sec_chan=1, width=1, seg0=122, seg1=0, cac_time=60s
Thu Oct 12 23:27:18 2023 daemon.info ModemManager[10339]: hotplug: add network interface phy0-ap0: event processed
Thu Oct 12 23:27:18 2023 daemon.debug ModemManager[10339]: hotplug: event reported: action=add, name=phy0-ap0, subsystem=net
Thu Oct 12 23:27:18 2023 daemon.err ModemManager[10339]: hotplug: parent device sysfspath not found
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: AP-DISABLED
Thu Oct 12 23:27:18 2023 daemon.err hostapd: hostapd_free_hapd_data: Interface phy0-ap0 wasn't started
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: nl80211: deinit ifname=phy0-ap0 disabled_11b_rates=0
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.894034] device phy0-ap0 left promiscuous mode
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.894209] br-lan: port 3(phy0-ap0) entered disabled state
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: interface state DFS->DISABLED
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.976197] br-lan: port 3(phy0-ap0) entered blocking state
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.976240] br-lan: port 3(phy0-ap0) entered disabled state
Thu Oct 12 23:27:18 2023 kern.info kernel: [  118.980804] device phy0-ap0 entered promiscuous mode
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: interface state DISABLED->COUNTRY_UPDATE
Thu Oct 12 23:27:18 2023 daemon.notice hostapd: phy0-ap0: DFS-CAC-COMPLETED success=0 freq=5620 ht_enabled=0 chan_offset=0 chan_width=3 cf1=5610 cf2=0
Thu Oct 12 23:27:18 2023 daemon.notice netifd: Wireless device 'radio0' is now up
Thu Oct 12 23:27:20 2023 daemon.info dnsmasq[1]: read /etc/hosts - 12 names
Thu Oct 12 23:27:20 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 4 names
Thu Oct 12 23:27:20 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Thu Oct 12 23:27:21 2023 daemon.info [6474]: <info>  [base-manager] couldn't check support for device '/sys/devices/platform/soc/c000000.wifi': not supported by any plugin
Thu Oct 12 23:28:21 2023 daemon.notice hostapd: phy0-ap0: DFS-CAC-COMPLETED success=1 freq=5620 ht_enabled=0 chan_offset=0 chan_width=3 cf1=5610 cf2=0
Thu Oct 12 23:28:21 2023 daemon.notice hostapd: phy0-ap0: interface state DFS->ENABLED
Thu Oct 12 23:28:21 2023 daemon.notice hostapd: phy0-ap0: AP-ENABLED
Thu Oct 12 23:28:23 2023 daemon.notice hostapd: phy0-ap0: DFS-PRE-CAC-EXPIRED freq=5580 ht_enabled=0 chan_offset=0 chan_width=0 cf1=5580 cf2=0
Thu Oct 12 23:28:23 2023 daemon.notice wpa_supplicant[4767]: phy0-sta0: Unknown event 54
Thu Oct 12 23:28:23 2023 daemon.notice hostapd: phy0-ap0: DFS-PRE-CAC-EXPIRED freq=5600 ht_enabled=0 chan_offset=0 chan_width=0 cf1=5600 cf2=0
Thu Oct 12 23:28:23 2023 daemon.notice hostapd: phy0-ap0: DFS-PRE-CAC-EXPIRED freq=5620 ht_enabled=0 chan_offset=0 chan_width=0 cf1=5620 cf2=0
Thu Oct 12 23:28:23 2023 daemon.notice hostapd: phy0-ap0: DFS-PRE-CAC-EXPIRED freq=5640 ht_enabled=0 chan_offset=0 chan_width=0 cf1=5640 cf2=0
Sun Oct 15 09:05:36 2023 daemon.err collectd[6591]: Sleeping only 2s because the next interval is 207352.165 seconds in the past!
Greetings William,
is there vanilla openwrt image you have made? if yes can you give me little tips how to test it so you can upload on openwrt directly as soon as possible?
-Jeva
Yes the images i produce are Vanilla openwrt images.
Simply boot you device into Uboot using Debrick via Uboot - GL.iNet Router Docs 4 (gl-inet.com)
Then only flash images that are in the snapshot folder only.
  • squashfs-nand-factory.ubi you flash in uboot which is access via the guide above
  • squashfs-nand-sysupgrade.bin you flash in LUCI after you flashed at least one of the openwrt native builds.
As always if you have issues you can ask for assistance but you take the risk on your own accord.
i am not sure if this could be hardware issue,
but my 2.4ghz wifi just restarts itself randomly. r24114 build snapshot.
And dont know where to look at.
Hi, as always Logs please and config with personal dtat removed.
Tue Oct 31 13:51:43 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
Tue Oct 31 14:01:43 2023 daemon.notice netifd: wan (5532): udhcpc: sending renew to server 194.16.0.0
Tue Oct 31 14:01:43 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
Tue Oct 31 14:11:43 2023 daemon.notice netifd: wan (5532): udhcpc: sending renew to server 194.16.0.0
Tue Oct 31 14:11:43 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
Tue Oct 31 14:12:57 2023 daemon.notice hostapd: phy1-ap0: AP-STA-DISCONNECTED bc:1d:89:86:5d:a8
Tue Oct 31 14:13:01 2023 daemon.info hostapd: phy1-ap0: STA bc:1d:89:86:5d:a8 IEEE 802.11: authenticated
Tue Oct 31 14:13:01 2023 daemon.info hostapd: phy1-ap0: STA bc:1d:89:86:5d:a8 IEEE 802.11: associated (aid 1)
Tue Oct 31 14:13:01 2023 daemon.notice hostapd: phy1-ap0: AP-STA-CONNECTED bc:1d:89:86:5d:a8 auth_alg=open
Tue Oct 31 14:13:01 2023 daemon.info hostapd: phy1-ap0: STA bc:1d:89:86:5d:a8 RADIUS: starting accounting session 68F236A73B0BC2BE
Tue Oct 31 14:13:01 2023 daemon.info hostapd: phy1-ap0: STA bc:1d:89:86:5d:a8 WPA: pairwise key handshake completed (RSN)
Tue Oct 31 14:13:01 2023 daemon.notice hostapd: phy1-ap0: EAPOL-4WAY-HS-COMPLETED bc:1d:89:86:5d:a8
Tue Oct 31 14:13:01 2023 daemon.info dnsmasq-dhcp[1]: DHCPREQUEST(br-lan) 192.168.1.7 bc:1d:89:86:5d:a8
Tue Oct 31 14:13:01 2023 daemon.info dnsmasq-dhcp[1]: DHCPACK(br-lan) 192.168.1.7 bc:1d:89:86:5d:a8 moto
Tue Oct 31 14:21:43 2023 daemon.notice netifd: wan (5532): udhcpc: sending renew to server 194.16.0.0
Tue Oct 31 14:21:43 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
Tue Oct 31 14:31:44 2023 daemon.notice netifd: wan (5532): udhcpc: sending renew to server 194.16.0.0
Tue Oct 31 14:31:44 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
Tue Oct 31 14:41:44 2023 daemon.notice netifd: wan (5532): udhcpc: sending renew to server 194.16.0.0
Tue Oct 31 14:41:44 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
Tue Oct 31 14:51:44 2023 daemon.notice netifd: wan (5532): udhcpc: sending renew to server 194.16.0.0
Tue Oct 31 14:51:44 2023 daemon.notice netifd: wan (5532): udhcpc: lease of 155.4.213.196 obtained from 194.16.0.0, lease time 1200
@jeva
From that excerpt all i am seeing is DHCP refreshing the address and on AP-STA-DISCONNECT.
Run from an ssh shell dmesg > output.txt then using scp root@<ip-address>:/root/output.txt . in a terminal to download the output file also do the same for Wireless config as well scp root@<ip-address>:/etc/config/wireless . make sure to edit that file to remove the SSID and PSK details as we don’t need them you can safely use * to redact that.
Then upload them somewhere safe that can then be linked and DM me the links
sorry for being naive but idk how to transfer file from scp.
i tried scp root@192.168.1.1:/root/out.txt but it throws help commands.---- I MANAGED
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x51af8014]
[ 0.000000] Linux version 6.1.56 (coder@devlab) (aarch64-openwrt-linux-musl-gcc (OpenWrt GCC 12.3.0 r24114-4e6aa44f86) 12.3.0, GNU ld (GNU Binutils) 2.40.0) #0 SMP Wed Oct 11 07:58:36 2023
[ 0.000000] Machine model: GL Technologies, Inc. AX1800
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x0000000040ffffff]
[ 0.000000] node 0: [mem 0x0000000041000000-0x000000004a5fffff]
[ 0.000000] node 0: [mem 0x000000004a600000-0x000000004e3fffff]
[ 0.000000] node 0: [mem 0x000000004e400000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 17 pages/cpu s31592 r8192 d29848 u69632
[ 0.000000] pcpu-alloc: s31592 r8192 d29848 u69632 alloc=174096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129024
[ 0.000000] Kernel command line: console=ttyMSM0,115200n8 ubi.mtd=rootfs root=mtd:ubi_rootfs rootfstype=squashfs rootwait root=/dev/ubiblock0_1
[ 0.000000] Dentry cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 420856K/524288K available (8128K kernel code, 874K rwdata, 2444K rodata, 1344K init, 289K bss, 103432K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv2m: range[mem 0x0b00a000-0x0b00affc], SPI[448:479]
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 and mmio timer(s) running at 24.00MHz (virt/virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
[ 0.000000] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000100] Calibrating delay loop (skipped), value calculated using timer frequency… 48.00 BogoMIPS (lpj=240000)
[ 0.000113] pid_max: default: 32768 minimum: 301
[ 0.000578] Mount-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.000591] Mountpoint-cache hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.002437] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.002445] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.002644] rcu: Hierarchical SRCU implementation.
[ 0.002648] rcu: Max phase no-delay instances is 1000.
[ 0.003302] smp: Bringing up secondary CPUs …
[ 0.003962] Detected VIPT I-cache on CPU1
[ 0.004083] CPU1: Booted secondary processor 0x0000000001 [0x51af8014]
[ 0.004745] Detected VIPT I-cache on CPU2
[ 0.004836] CPU2: Booted secondary processor 0x0000000002 [0x51af8014]
[ 0.005459] Detected VIPT I-cache on CPU3
[ 0.005548] CPU3: Booted secondary processor 0x0000000003 [0x51af8014]
[ 0.005615] smp: Brought up 1 node, 4 CPUs
[ 0.005623] SMP: Total of 4 processors activated.
[ 0.005628] CPU features: detected: 32-bit EL0 Support
[ 0.005632] CPU features: detected: CRC32 instructions
[ 0.005696] CPU features: emulated: Privileged Access Never (PAN) using TTBR0_EL1 switching
[ 0.005702] CPU: All CPU(s) started at EL1
[ 0.005704] alternatives: applying system-wide alternatives
[ 0.013145] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.013171] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.013398] pinctrl core: initialized pinctrl subsystem
[ 0.014855] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.015413] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.015465] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.015502] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.015883] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.016090] cpuidle: using governor menu
[ 0.016407] ASID allocator initialised with 65536 entries
[ 0.077904] SCSI subsystem initialized
[ 0.078147] usbcore: registered new interface driver usbfs
[ 0.078186] usbcore: registered new interface driver hub
[ 0.078221] usbcore: registered new device driver usb
[ 0.078502] qcom_scm: convention: smc arm 64
[ 0.079962] clocksource: Switched to clocksource arch_sys_counter
[ 0.081153] NET: Registered PF_INET protocol family
[ 0.081293] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.082291] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 4096 bytes, linear)
[ 0.082311] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.082324] TCP established hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.082372] TCP bind hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.082516] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.082608] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.082633] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.082819] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.082855] PCI: CLS 0 bytes, default 64
[ 0.084205] workingset: timestamp_bits=46 max_order=17 bucket_order=0
[ 0.089164] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.089175] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.090241] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.092168] qcom-qmp-usb-phy 78000.ssphy: supply vdda-phy not found, using dummy regulator
[ 0.092331] qcom-qmp-usb-phy 78000.ssphy: supply vdda-pll not found, using dummy regulator
[ 0.093967] qcom-qusb2-phy 59000.qusb: supply vdd not found, using dummy regulator
[ 0.094113] qcom-qusb2-phy 59000.qusb: supply vdda-pll not found, using dummy regulator
[ 0.094184] qcom-qusb2-phy 59000.qusb: supply vdda-phy-dpdm not found, using dummy regulator
[ 0.094329] qcom-qusb2-phy 59000.qusb: Registered Qcom-QUSB2 phy
[ 0.094528] qcom-qusb2-phy 79000.qusb: supply vdd not found, using dummy regulator
[ 0.094638] qcom-qusb2-phy 79000.qusb: supply vdda-pll not found, using dummy regulator
[ 0.094707] qcom-qusb2-phy 79000.qusb: supply vdda-phy-dpdm not found, using dummy regulator
[ 0.094867] qcom-qusb2-phy 79000.qusb: Registered Qcom-QUSB2 phy
[ 0.099124] bam-dma-engine 704000.dma-controller: num-channels unspecified in dt
[ 0.099139] bam-dma-engine 704000.dma-controller: num-ees unspecified in dt
[ 0.104361] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.106469] msm_serial 78b1000.serial: msm_serial: detected port #0
[ 0.106508] msm_serial 78b1000.serial: uartclk = 1843200
[ 0.106603] 78b1000.serial: ttyMSM0 at MMIO 0x78b1000 (irq = 21, base_baud = 115200) is a MSM
[ 0.106632] msm_serial: console setup on port #0
[ 0.799174] printk: console [ttyMSM0] enabled
[ 0.804363] msm_serial: driver initialized
[ 0.813299] loop: module loaded
[ 0.813379] Loading iSCSI transport class v2.0-870.
[ 0.817104] nand: device found, Manufacturer ID: 0xf8, Chip ID: 0xa1
[ 0.820149] nand: Unknown FMND1G08S3D
[ 0.826710] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 0.844530] i2c_dev: i2c /dev entries driver
[ 0.849519] sdhci: Secure Digital Host Controller Interface driver
[ 0.849566] sdhci: Copyright(c) Pierre Ossman
[ 0.854646] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.861690] remoteproc remoteproc0: releasing cd00000.remoteproc
[ 0.867106] NET: Registered PF_INET6 protocol family
[ 0.871814] Segment Routing with IPv6
[ 0.875731] In-situ OAM (IOAM) with IPv6
[ 0.879329] NET: Registered PF_PACKET protocol family
[ 0.883299] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 0.888332] 8021q: 802.1Q VLAN Support v1.8
[ 0.926932] nand: device found, Manufacturer ID: 0xf8, Chip ID: 0xa1
[ 0.926974] nand: Unknown FMND1G08S3D
[ 0.932384] nand: 128 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 0.936201] 11 qcomsmem partitions found on MTD device qcom_nand.0
[ 0.943410] Creating 11 MTD partitions on “qcom_nand.0”:
[ 0.949547] 0x000000000000-0x000000180000 : “0:sbl1”
[ 0.957070] 0x000000180000-0x000000280000 : “0:mibib”
[ 0.961461] 0x000000280000-0x000000600000 : “0:qsee”
[ 0.968641] 0x000000600000-0x000000680000 : “0:devcfg”
[ 0.970935] 0x000000680000-0x000000700000 : “0:rpm”
[ 0.975828] 0x000000700000-0x000000780000 : “0:cdt”
[ 0.980630] 0x000000780000-0x000000800000 : “0:appsblenv”
[ 0.985492] 0x000000800000-0x000000980000 : “0:appsbl”
[ 0.992030] 0x000000980000-0x000000a00000 : “0:art”
[ 0.996070] 0x000000a00000-0x000007d00000 : “rootfs”
[ 1.107309] mtd: setting mtd9 (rootfs) as root device
[ 1.107684] mtdsplit: no squashfs found in “rootfs”
[ 1.111401] 0x000007d00000-0x000007d80000 : “0:ethphyfw”
[ 1.121860] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 799999 KHz, changing to: 864000 KHz
[ 1.123890] remoteproc remoteproc0: cd00000.remoteproc is available
[ 1.132875] ubi0: attaching mtd9
[ 1.801927] ubi0: scanning is finished
[ 1.810112] ubi0: attached mtd9 (name “rootfs”, size 115 MiB)
[ 1.810152] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 1.814845] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 1.821633] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 1.828473] ubi0: good PEBs: 920, bad PEBs: 0, corrupted PEBs: 0
[ 1.835250] ubi0: user volume: 3, internal volumes: 1, max. volumes count: 128
[ 1.841502] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1697011116
[ 1.848531] ubi0: available PEBs: 0, total reserved PEBs: 920, PEBs reserved for bad PEB handling: 20
[ 1.857838] ubi0: background thread “ubi_bgt0d” started, PID 424
[ 1.858735] block ubiblock0_1: created from ubi0:1(rootfs)
[ 1.877469] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 1.878177] Freeing unused kernel memory: 1344K
[ 1.910039] Run /sbin/init as init process
[ 1.910061] with arguments:
[ 1.910064] /sbin/init
[ 1.910067] with environment:
[ 1.910070] HOME=/
[ 1.910073] TERM=linux
[ 2.160276] init: Console is alive
[ 2.160452] init: - watchdog -
[ 2.679973] random: crng init done
[ 3.336764] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 3.363523] Button Hotplug driver version 0.4.1
[ 3.531729] malibu_phy_api_ops_init[2854]:INFO:qca probe malibu phy driver succeeded!
[ 3.890372] __adpt_hppe_uniphy_psgmii_mode_set[1115]:INFO:uniphy 0 psgmii channel selection
[ 4.115275] regi_init[3989]:INFO:Initializing HPPE Done!!
[ 4.115388] regi_init[4049]:INFO:qca-ssdk module init succeeded!
[ 4.122338] EDMA ver 1 hw init
[ 4.125938] EDMA HW Reset completed succesfully
[ 4.128613] Num rings - TxDesc:1 (23-23) TxCmpl:1 (23-23)
[ 4.133039] RxDesc:1 (15-15) RxFill:1 (7-7)
[ 4.141282] GMAC3(ffffff800314b940) Invalid MAC@ - using 0e:0a:53:3b:f6:e8
[ 4.143568] GMAC4(ffffff800314a940) Invalid MAC@ - using 96:97:8e:3c:ea:34
[ 4.150574] GMAC5(ffffff8003969940) Invalid MAC@ - using be:2b:24:88:7f:fb
[ 4.157333] **********************************************************
[ 4.163248] * NSS Data Plane driver
[ 4.169724] **********************************************************
[ 4.197456] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 4.197510] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 1
[ 4.202022] xhci-hcd xhci-hcd.1.auto: USB3 root hub has no ports
[ 4.209394] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x0000000000010010
[ 4.215718] xhci-hcd xhci-hcd.1.auto: irq 33, io mem 0x07000000
[ 4.225439] hub 1-0:1.0: USB hub found
[ 4.230740] hub 1-0:1.0: 1 port detected
[ 4.234952] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 4.238573] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
[ 4.244807] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe65 hci version 0x110 quirks 0x0000000000010010
[ 4.251468] xhci-hcd xhci-hcd.2.auto: irq 34, io mem 0x08a00000
[ 4.260932] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 4.266690] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 3
[ 4.272257] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
[ 4.280292] hub 2-0:1.0: USB hub found
[ 4.286418] hub 2-0:1.0: 1 port detected
[ 4.290535] usb usb3: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 4.294644] hub 3-0:1.0: USB hub found
[ 4.302314] hub 3-0:1.0: 1 port detected
[ 4.311137] input: keys as /devices/platform/keys/input/input0
[ 4.313060] usbcore: registered new interface driver usb-storage
[ 4.316971] usbcore: registered new interface driver uas
[ 4.322382] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 4.334756] init: - preinit -
[ 7.300252] nss-dp 3a001200.dp eth1: PHY Link up speed: 1000
[ 7.300346] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 7.321696] mount_root: loading kmods from internal overlay
[ 7.351671] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 7.356378] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 7.422059] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 7.526223] UBIFS (ubi0:2): Mounting in unauthenticated mode
[ 7.526373] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 675
[ 7.567763] UBIFS (ubi0:2): recovery needed
[ 7.678718] UBIFS (ubi0:2): recovery completed
[ 7.678815] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name “rootfs_data”
[ 7.682075] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 7.689971] UBIFS (ubi0:2): FS size: 84946944 bytes (81 MiB, 669 LEBs), max 680 LEBs, journal size 4317184 bytes (4 MiB, 34 LEBs)
[ 7.699859] UBIFS (ubi0:2): reserved for root: 4012253 bytes (3918 KiB)
[ 7.711490] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID 03F3A769-38BC-440B-9E44-B80DEAE7BAD6, small LPT model
[ 7.719090] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 7.734590] block: extroot: not configured
[ 7.736279] UBIFS (ubi0:2): un-mount UBI device 0
[ 7.740335] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” stops
[ 7.748559] UBIFS (ubi0:2): Mounting in unauthenticated mode
[ 7.751279] UBIFS (ubi0:2): background thread “ubifs_bgt0_2” started, PID 678
[ 7.819925] UBIFS (ubi0:2): UBIFS: mounted UBI device 0, volume 2, name “rootfs_data”
[ 7.819988] UBIFS (ubi0:2): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 7.826767] UBIFS (ubi0:2): FS size: 84946944 bytes (81 MiB, 669 LEBs), max 680 LEBs, journal size 4317184 bytes (4 MiB, 34 LEBs)
[ 7.836680] UBIFS (ubi0:2): reserved for root: 4012253 bytes (3918 KiB)
[ 7.848297] UBIFS (ubi0:2): media format: w5/r0 (latest is w5/r0), UUID 03F3A769-38BC-440B-9E44-B80DEAE7BAD6, small LPT model
[ 7.858958] mount_root: loading kmods from internal overlay
[ 7.892233] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 7.893728] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 7.905649] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 7.946198] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 7.949617] block: extroot: not configured
[ 7.953631] mount_root: switching to ubifs overlay
[ 7.964078] overlayfs: null uuid detected in lower fs ‘/’, falling back to xino=off,index=off,nfs_export=off.
[ 7.978229] nss-dp 3a001200.dp eth1: PHY Link is down
[ 7.988705] procd: - early -
[ 7.988843] procd: - watchdog -
[ 8.570816] procd: - watchdog -
[ 8.571109] procd: - ubus -
[ 8.727201] procd: - init -
[ 9.652566] kmodloader: loading kernel modules from /etc/modules.d/*
[ 9.728418] NET: Registered PF_ALG protocol family
[ 9.739048] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 9.741770] tun: Universal TUN/TAP device driver, 1.6
[ 9.754381] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 9.756640] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 9.766199] nat46: module (version 4c5beee236841724219598fabb1edc93d4f08ce5) loaded.
[ 9.769088] gre: GRE over IPv4 demultiplexor driver
[ 9.774983] ip_gre: GRE over IPv4 tunneling driver
[ 9.783462] ip6_gre: GRE over IPv6 tunneling driver
[ 9.791722] ksmbd: The ksmbd server is experimental
[ 9.832321] cryptodev: driver 1.12 loaded.
[ 9.842594] GACT probability on
[ 9.843559] Mirror/redirect action on
[ 9.850586] u32 classifier
[ 9.850619] input device check on
[ 9.852188] Actions configured
[ 9.868261] Simple TC action Loaded
[ 9.903753] Bridge firewalling registered
[ 9.904890] usbcore: registered new interface driver cdc_wdm
[ 9.908541] Loading modules backported from Linux version v6.5-0-g2dde18cd1d8f
[ 9.912510] Backport generated by backports.git v5.15.92-1-56-g5fb2ccb6b9e8
[ 9.947419] NET: Registered PF_QIPCRTR protocol family
[ 9.963578] usbcore: registered new interface driver usbserial_generic
[ 9.963672] usbserial: USB Serial support registered for generic
[ 10.012688] xt_time: kernel timezone is -0000
[ 10.015079] usbcore: registered new interface driver cdc_ether
[ 10.018096] usbcore: registered new interface driver cdc_ncm
[ 10.039883] usbcore: registered new interface driver huawei_cdc_ncm
[ 10.062082] PPP generic driver version 2.4.2
[ 10.063988] NET: Registered PF_PPPOX protocol family
[ 10.067043] usbcore: registered new interface driver qmi_wwan
[ 10.074805] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
[ 10.076021] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
[ 10.093756] ath11k c000000.wifi: ipq6018 hw1.0
[ 10.093796] ath11k c000000.wifi: FW memory mode: 1
[ 10.098045] remoteproc remoteproc0: powering up cd00000.remoteproc
[ 10.104991] remoteproc remoteproc0: Booting fw image IPQ6018/q6_fw.mdt, size 7340
[ 10.155613] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.208203] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.264679] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.334395] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.408560] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.480403] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.550320] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.621555] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.695346] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.769186] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.842749] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.907829] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 10.967966] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.025543] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.076239] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.127020] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.177838] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.228643] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.283139] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.286792] remoteproc remoteproc0: remote processor cd00000.remoteproc is now up
[ 11.288012] ath11k c000000.wifi: qmi ignore invalid mem req type 3
[ 11.299089] usbcore: registered new interface driver option
[ 11.299487] ath11k c000000.wifi: chip_id 0x0 chip_family 0x4 board_id 0xff soc_id 0xffffffff
[ 11.304802] usbserial: USB Serial support registered for GSM modem (1-port)
[ 11.310214] ath11k c000000.wifi: fw_version 0x250a04b8 fw_build_timestamp 2021-12-20 07:20 fw_build_id WLAN.HK.2.5.0.1-01208-QCAHKSWPL_SILICONZ-1
[ 11.327961] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 11.403164] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 11.856105] mtdblock: MTD device ‘rootfs’ is NAND, please consider using UBI block devices instead.
[ 15.798226] br-lan: port 1(eth1) entered blocking state
[ 15.798275] br-lan: port 1(eth1) entered disabled state
[ 15.802603] device eth1 entered promiscuous mode
[ 15.819064] br-lan: port 2(eth2) entered blocking state
[ 15.819112] br-lan: port 2(eth2) entered disabled state
[ 15.823483] device eth2 entered promiscuous mode
[ 15.837252] br-lan: port 3(eth3) entered blocking state
[ 15.837303] br-lan: port 3(eth3) entered disabled state
[ 15.841670] device eth3 entered promiscuous mode
[ 15.857178] br-lan: port 4(eth4) entered blocking state
[ 15.857224] br-lan: port 4(eth4) entered disabled state
[ 15.861533] device eth4 entered promiscuous mode
[ 16.420172] br-lan: port 5(phy1-ap0) entered blocking state
[ 16.420219] br-lan: port 5(phy1-ap0) entered disabled state
[ 16.424802] device phy1-ap0 entered promiscuous mode
[ 16.444973] br-lan: port 5(phy1-ap0) entered blocking state
[ 16.445021] br-lan: port 5(phy1-ap0) entered forwarding state
[ 16.450180] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
[ 16.806820] br-lan: port 5(phy1-ap0) entered disabled state
[ 18.400172] IPv6: ADDRCONF(NETDEV_CHANGE): phy1-ap0: link becomes ready
[ 18.400385] br-lan: port 5(phy1-ap0) entered blocking state
[ 18.405612] br-lan: port 5(phy1-ap0) entered forwarding state
[ 18.895739] nss-dp 3a001200.dp eth1: PHY Link up speed: 1000
[ 18.895855] br-lan: port 1(eth1) entered blocking state
[ 18.900521] br-lan: port 1(eth1) entered forwarding state
[ 18.970546] nss-dp 3a001000.dp eth0: PHY Link up speed: 1000
[ 18.970627] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 20.010458] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[ 20.010538] br-lan: port 2(eth2) entered blocking state
[ 20.015196] br-lan: port 2(eth2) entered forwarding state
[ 5517.442356] nss-dp 3a001400.dp eth2: PHY Link is down
[ 5517.442773] br-lan: port 2(eth2) entered disabled state
[13068.872867] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[13068.872949] br-lan: port 2(eth2) entered blocking state
[13068.877606] br-lan: port 2(eth2) entered forwarding state
[13090.712682] nss-dp 3a001400.dp eth2: PHY Link is down
[13090.713087] br-lan: port 2(eth2) entered disabled state
[13100.072865] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[13100.072944] br-lan: port 2(eth2) entered blocking state
[13100.077602] br-lan: port 2(eth2) entered forwarding state
[19881.902434] nss-dp 3a001400.dp eth2: PHY Link is down
[19881.902849] br-lan: port 2(eth2) entered disabled state
[43169.475783] nss-dp 3a001200.dp eth1: PHY Link is down
[43169.485954] br-lan: port 1(eth1) entered disabled state
[43195.475893] nss-dp 3a001200.dp eth1: PHY Link up speed: 1000
[43195.475978] br-lan: port 1(eth1) entered blocking state
[43195.480634] br-lan: port 1(eth1) entered forwarding state
[63336.255286] ath11k c000000.wifi: failed to flush transmit queue, data pkts pending 80
[67724.971995] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[67724.972075] br-lan: port 2(eth2) entered blocking state
[67724.976734] br-lan: port 2(eth2) entered forwarding state
[67747.851866] nss-dp 3a001400.dp eth2: PHY Link is down
[67747.852273] br-lan: port 2(eth2) entered disabled state
[67757.211952] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[67757.212035] br-lan: port 2(eth2) entered blocking state
[67757.216689] br-lan: port 2(eth2) entered forwarding state
[79431.196399] nss-dp 3a001400.dp eth2: PHY Link is down
[79431.196817] br-lan: port 2(eth2) entered disabled state
[79466.556494] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[79466.556577] br-lan: port 2(eth2) entered blocking state
[79466.561232] br-lan: port 2(eth2) entered forwarding state
[79541.436185] nss-dp 3a001400.dp eth2: PHY Link is down
[79541.437171] br-lan: port 2(eth2) entered disabled state
[79570.556345] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[79570.556431] br-lan: port 2(eth2) entered blocking state
[79570.561089] br-lan: port 2(eth2) entered forwarding state
[79850.315869] nss-dp 3a001400.dp eth2: PHY Link is down
[79850.316278] br-lan: port 2(eth2) entered disabled state
[99896.293227] br-lan: port 2(eth2) entered blocking state
[99896.297884] br-lan: port 2(eth2) entered forwarding state
[101193.171900] nss-dp 3a001800.dp eth4: PHY Link up speed: 100
[101193.171981] br-lan: port 4(eth4) entered blocking state
[101193.176638] br-lan: port 4(eth4) entered forwarding state
[158823.676698] br-lan: port 2(eth2) entered blocking state
[158823.681354] br-lan: port 2(eth2) entered forwarding state
[174252.052979] nss-dp 3a001400.dp eth2: PHY Link is down
[174252.053395] br-lan: port 2(eth2) entered disabled state
[190903.470650] nss-dp 3a001800.dp eth4: PHY Link up speed: 100
[190903.470731] br-lan: port 4(eth4) entered blocking state
[190903.475388] br-lan: port 4(eth4) entered forwarding state
[190905.550521] nss-dp 3a001800.dp eth4: PHY Link is down
[190905.550953] br-lan: port 4(eth4) entered disabled state
[190908.670620] nss-dp 3a001800.dp eth4: PHY Link up speed: 100
[190908.670704] br-lan: port 4(eth4) entered blocking state
[190908.675359] br-lan: port 4(eth4) entered forwarding state
[194994.826568] nss-dp 3a001800.dp eth4: PHY Link is down
[194994.826863] br-lan: port 4(eth4) entered disabled state
[219568.879336] nss-dp 3a001200.dp eth1: PHY Link is down
[219568.889465] br-lan: port 1(eth1) entered disabled state
[219594.879426] nss-dp 3a001200.dp eth1: PHY Link up speed: 1000
[219594.879511] br-lan: port 1(eth1) entered blocking state
[219594.884165] br-lan: port 1(eth1) entered forwarding state
[305968.846915] nss-dp 3a001200.dp eth1: PHY Link is down
[305968.857084] br-lan: port 1(eth1) entered disabled state
[305994.847065] nss-dp 3a001200.dp eth1: PHY Link up speed: 1000
[305994.847147] br-lan: port 1(eth1) entered blocking state
[305994.851805] br-lan: port 1(eth1) entered forwarding state
[328280.019474] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[328280.019557] br-lan: port 2(eth2) entered blocking state
[328280.024214] br-lan: port 2(eth2) entered forwarding state
[328309.139292] nss-dp 3a001400.dp eth2: PHY Link is down
[328309.139586] br-lan: port 2(eth2) entered disabled state
[328318.499432] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[328318.499513] br-lan: port 2(eth2) entered blocking state
[328318.504170] br-lan: port 2(eth2) entered forwarding state
[331511.295210] nss-dp 3a001400.dp eth2: PHY Link is down
[331511.295638] br-lan: port 2(eth2) entered disabled state
[333385.372351] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[333385.372433] br-lan: port 2(eth2) entered blocking state
[333385.377090] br-lan: port 2(eth2) entered forwarding state
[333409.292053] nss-dp 3a001400.dp eth2: PHY Link is down
[333409.292479] br-lan: port 2(eth2) entered disabled state
[333418.652314] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[333418.652400] br-lan: port 2(eth2) entered blocking state
[333418.657056] br-lan: port 2(eth2) entered forwarding state
[341331.997090] nss-dp 3a001400.dp eth2: PHY Link is down
[341331.997520] br-lan: port 2(eth2) entered disabled state
[350105.418749] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[350105.418830] br-lan: port 2(eth2) entered blocking state
[350105.423490] br-lan: port 2(eth2) entered forwarding state
[350132.458534] nss-dp 3a001400.dp eth2: PHY Link is down
[350132.458987] br-lan: port 2(eth2) entered disabled state
[350141.818621] nss-dp 3a001400.dp eth2: PHY Link up speed: 1000
[350141.818703] br-lan: port 2(eth2) entered blocking state
[350141.823361] br-lan: port 2(eth2) entered forwarding state
[352611.814437] nss-dp 3a001800.dp eth4: PHY Link up speed: 100
[352611.814519] br-lan: port 4(eth4) entered blocking state
[352611.819178] br-lan: port 4(eth4) entered forwarding state
[352613.894350] nss-dp 3a001800.dp eth4: PHY Link is down
[352613.894758] br-lan: port 4(eth4) entered disabled state
[352615.974438] nss-dp 3a001800.dp eth4: PHY Link up speed: 100
[352615.974525] br-lan: port 4(eth4) entered blocking state
[352615.979178] br-lan: port 4(eth4) entered forwarding state
[353745.572090] ath11k c000000.wifi: failed to flush transmit queue, data pkts pending 5
wireless logs are here -----
config wifi-device 'radio0'
	option type 'mac80211'
	option path 'platform/soc/c000000.wifi'
	option channel '36'
	option band '5g'
	option htmode 'HE80'
	option disabled '1'
config wifi-iface 'default_radio0'
	option device 'radio0'
	option network 'lan'
	option mode 'ap'
	option ssid 'OpenWrt'
	option encryption 'none'
config wifi-device 'radio1'
	option path 'platform/soc/c000000.wifi+1'
	option channel '9'
	option band '2g'
	option htmode 'HE40'
	option cell_density '0'
config wifi-iface 'default_radio1'
	option device 'radio1'
	option mode 'ap'
	option ssid 'x'
	option encryption 'sae-mixed'
	option key 'x'
	option wpa_disable_eapol_key_retries '1'
Right thank you and this line i see many times so a question is required to be asked as that is related to QCA’s buggy wireless firmware.
The question is about sae-mixed is this fully required, does the issue on 2.4Ghz still happen if the encryption is set to any other encryption method.
Other then that its booting correctly.
As for scp i always assume Linux or Windows which scp command as set out as stated would work if you was on a Mac however a scp -O would of been needed if i remember correctly.
Anyway try a different ecryption method first to narrow the issue down.
Tried with WPA2-PSK(force CCMP, TKIP), WPA3-SAE got same problem in log.
currently testing WPA-PSK/WPA2-PSK mixed.
WPA-PSK/WPA2-PSK mixed and WPA-PSK give same error code by different process ID in the end.
Ok this doesn’t sound good, as mine aka all 5 of mine do not have this issue.
Is your area congested in the 2.4Ghz band? If so try setting a channel that is not in use so keeping away from 1-6-11 see if that helps else it could be hardware issue possibly does 5Ghz also show this issue ?
I did try every band, in my area in one room channel 5 works better and in other channel 11,
Still there are multiple ssid overlaping (approx 5).
Interesting thing happened right after changing channel.
  1. WIFI still crashes and restart itself, but it doesn’t take a minute like it used to before, now it takes only around 15 seconds maximum.
  2. Completely turned off 5ghz and after this 2.4ghz signal strength is better.
  3. Cant use WPA3 SAE due to old printer (brother dcp-1610w) only supports wpa2, although it does support IPv6 and printer uses EUI64, but dont have knowlegde how to reserve address via dhcpv6 in openwrt.
So overall wondering if ipv6 and wpa3 goes hand in hand, or WPA security is plainly for client to host security rather than protocol security
I know from personal experience there is issues with WPA3 even in a mixed wpa2/3 mode where it’s not supported by a device or even an OS supports it but it’s very buggy which is why I still use WPA2 and an allowed lost for main network.
As for IPv6 I have no knowledge either as my network is pure ipv4 only.
So I can’t help you on that.
However the issue sounds like a firmware blob from QCA issue more then anything and they haven’t touched it since v 2.7 which crashes because of more bugs.
If I have time will tell you how to pull the firmware blobs from gl-inets image and use on OpenWRT build.
I also noticed that (at least as of a few weeks ago) it is impossible to connect a USB3 device, it always gets attached to the USB2 hub. I also know there are vendor-specific kernel patches for this chipset but was unable to figure out how to improve the situation despite trying various things.
Steps to repro: Use solidus1983 awesome firmware and plug in a usb3 device and run lsusb -t. Notice that it’s connected to the 480M (USB2) hub. Next, try with GL-iNet firmware. Now it’s connected to 5000M (USB3) hub.
well, package is not listed in solidus’s repo
I installed gl.inet firmware again, and seems like “ath11k c000000.wifi: failed to flush transmit queue, data pkts pending” this problem is presistent.
Now the duration of wifi restart is more lol. i am out of ideas, back to your image again (atleast restart is quick in yours image.)
Good day @solidus1983 !
Just wondering if you had time to look into this and if there is hope. :sunglasses:
Are you aware of others working on this and if yes would you mind sharing their GitHub link please.
Thank you!
I haven’t had time yet. Yes I am aware others are working on the SOC at hand here. Myself and Shi whom I fork from currently on my repo.
Thank you for the update!
