I tried that Snapshot last night when I first saw it available...Tried several times installing...Wound up with a brick each time...Could not connect to it and could not SSH into it (Did not keep settings when flashing from gl.inet firmware)...Could not even ping it...You'll also notice you can't build a customized version yet on the Firmware Selector... I think it's still a work in progress...
Do not try to upgrade directly as a sysupgrade image from the GL-Inet software, even from luci over in advanced... Installing sysupgrade will likely result in a device that can't talk - it's not bricked however, uboot recovery can get things back up and running...
qualcommax: ipq60xx: add GL.iNet GL-AX1800/AXT1800 support
SoC: Qualcomm IPQ6000
RAM: 512 MiB
Flash: 128 MiB NAND
ETH: Qualcomm QCA8075
WLAN1: 2.4GHz 802.11b/g/n/ax 2x2
WLAN2: 5GHz 802.11a/n/ac/ax 2x2
Button: Reset, Switch
USB: 1x 3.0
SD slot: 1 in GL-AXT1800
Install via stock firmware:
Upload factory.bin in stock firmware's upgrade page,
do not preserve settings.
Install via uboot web failsafe:
Push the reset button for 5 seconds, then use broswer
to access http://192.168.1.1, and upload factory.ubi.
Afterwards upgrade can use sysupgrade image.
factory.ubi from u-boot recovery works fine for first flash over from gl-inet firmware.
Thanks...That's interesting because I can flash Snapshots from GL.inet Flint2 firmware without issue...If I flash factory.ubi from uboot on the Flint 1 can I get back to GL.inet Firmware (easily)??
Thanks for the info...Did not realize that about the factory.bin and factory.ubi files...
I'm back on GL.inet firmware right now...Will try again later with factory.ubi.
MT6000 is a very different platform compared to the AX/AXT1800's...
Nice to see at the moment as we can have an apples/apples compare between MediaTek and Qualcomm - MT6000 has an advantage with the 4*4:4 radios and more clocks, but Qualcomm's radios are generally better, IMHO...
Anyways - it'll be interesting to see how things go - I've got a Flint2 on hand, and a SlateAX as well - and a Flint(1) on order...
Well what happened was a whole lotta nuttin'...
Armed with factory.bin, factory.ubi, and sysupgrade.bin (All for the AX1800 from the Firmware Selector Page)...I first tried factory.bin from the gl.inet web interface...Had to do a forced install...
Did not work and required entering into UBOOT...Next I tried factory.ubi from UBOOT...Nothing...Had to get back into UBOOT...OK..Tried Factory.bin from UBOOT...Nothing...Had to get back to UBOOT...And I had previously tried sysupgrade.bin from UBOOT and GL.inet Web interface and I already knew that didn't work either...Not sure what is going on...My UBOOT version is 2.0 which I believe is the most current for the FLINT 1 Router...So I just flashed GL.inet 4.70 firmware back and retored config for now...The FLINT 1 serves as just a backup router for my Flint 2 (I owned the Flint 1 about a year before the Flint 2 came out)...Guess I'll just standby on this and monitor the forums and see what the uptake is on this...
Yeah...UP and RUNNING...
Noticed today that I could build a custom firmware on the OpenWRT Firmware Selector...
Used the same build list to build a custom firmware for my FLINT 1 the same as my FLINT 2.
Success...Downloaded factory.bin, factory.ubi and systupgrade.bin.
At first tried loading the factory.ubi through the Flint 1's UBOOT...I was using my Brave Browser and it was not processing the request. I switched to Firefox Browser...I was then able to upload the factory.ubi via UBOOT (It took quite a few minutes)...Success...I now had OpenWRT r29091 running on my FLINT 1...Next I restored my saved config from my FLINT 2 as my custom build had the SAME packages for my FLINT 1 as it did on my FLINT 2...After reboot everything looked good...I swapped the FLINT 1 in place of the FLINT 2 putting the FLINT 1 online...
Upon boot everything looked OK but I did not have internet...The WAN port was not started. Eventually I figured out that the WAN port had eth1 configured and not WAN in the WAN settings...Once I set it to WAN and restarted it it connected and I had internet and my VPN also automatially started and is working correctly...Everything looks good...So nice to have FLINT 1 now on the same OpenWRT setup as my FLINT 2...Will leave it online today for testing...
Turned out that yesterday's problems were all due to the files that were being offered. Today's files that I did a custom build solved everything. Oh...And the GL.inet UBOOT is intact so that means switching back and forth between GL.inet Firmware and OpenWRT firmware remains easy.
EDIT: I did have to ssh into the router and correct /etc/config/wireless file as it had two entries for the radios in my Flint2 (Since I restored the config from the Flint2)...Simply removed those two entries radio0 and radio1...Then renamed the valid radio entries to radio0 and radio1 correcting names within the sections as well. Now 2.4 and 5Ghz radios are correct in the Flint 1 config and working great (tested). Backed up new config. Everything working.
Yesterday I used the firmware selector for GL-AXT1800 and custom build option adding the additional packages that I use for WireGuard, DDNS, https-dns and pbr. Installed the .ubi and everything appears to be working great. So I am encouraged.
