You mean this one?
Yes that one. It’s what the last 2 builds have been based off
I just compiled this version. Should block-mount be built-in for sdcard support on the axt1800?
I have a Flint with lastest Gl.inet official FW 4.5.x and want to go for pure OpenWRT, because i need a config with 2x wireguard clients in 2 different VLANs, and GL.inet gui is messing up my config, even on no changes.
Questions:
can i flash your firmware with stock glinet uboot or do i need to flash another uboot version first?
- Your flashing instructions telling to use …squashfs**-nand-**factory.ubi image.
the latest snapshot image on your server - dated 2024-04-28 - is named “openwrt-qualcommax-ipq60xx-glinet_gl-ax1800-squashfs-factory” - no -nand- in the filename.
Is this just typo, flash it anyway, or do i need to flash the older nand…ubi image dated 2024-02-20 first, and then upgrade ?
i don’t think it needs to be, not 100% sure.
Yes i need to update the Legend, that’s the old file name, So long as the ending is factory.ubi then its the correct file.
@solidus1983 Thank you for your work on this.
Wondering if you test Repeater mode.
Your last experimental, is unusable, crashes and lots of errors, let me know if logo are still useful.
Snapshot from April 28, doesn’t work for me as a station on 5G, here the error I get:
So I see that the PR needs 6 reviews in order to be promoted.
EDIT: there are only a few file changes used to implement these routers, that is pretty amazing.
This can be done by going to the software area and updating the list, then looking for WPA-Supplicant and installing it.
Logs is always handy.
There was far more files and patches to begin with, however most fixes have been up-streamed into the Linux kernel thus making the required amount of files smaller.
FWIW I tested repeater mode on my axt1800 for several hours and didn’t experience any issues.
I'm sorry this is can be off-top, but I'd like to ask you the question.
How difficult to build passwall client (GitHub - xiaorouji/openwrt-passwall) for this build of openwrt?
Thank you for your response.
Did you test repeating DFS channels on 5G ?
No, I don't use DFS channels
nodejs package does not work. when I install is and run 'node' command, it exits immediately with segmentation fault
George Sears? It's been a while. Mr. President, may I have said link to upgrade my uboot please? I asked chatpGTP and he did not know.
uboot-ipq60xx/uboot-gl-ax1800-20220711-md5-9890c67c3dafa5aec172f3a31583f9a7.bin at master · gl-inet/uboot-ipq60xx · GitHub is the only one available.
Dear Solidus1983, thank for your effort to support AXT1800 owners, its a good piece of equipment which really needs new updates to survive.
I have installed your r26072 to run V2rayA with vless. The tunnel established without troubles, however the "tproxy" tranparent proxy option in setup returnes the following error. Other proxy options also do not route properly. I have same setup with Mango and Beryl, no such problems with them. Any idea how to solve?
failed to start v2ray-core: not support "tproxy" mode of transparent proxy: ExecCommands: iptables -w 2 -t mangle -A TP_OUT -p tcp -m addrtype --src-type LOCAL ! --dst-type LOCAL -j TP_RULE iptables v1.8.8 (nf_tables): Couldn't load match addrtype':No such file or directory Try iptables -h' or 'iptables --help' for more information. : exit status 2
Hej man, Merry christmas.
Merry Christmas to you all as well
