GL.iNet B3000 crashing everyday
I bought a GL.iNet B3000 this month, but after using it some time, it starts to crash (well at least the DNS and Router itself, Internet still kinda works as long as the DNS Server isn't needed)
I activated AdGuard Home on the Router and it was my main reason for buying this router. Do I need to adjust some settings? The only thing I did after enabling AdGuard was adding some lists:
Also right now, I realized that RAM, CPU and tmp folder usage is high.
What should I do to fix this?
This model don't have enough power (CPU and memory) to handle so many filters.
I had the same problem and I reported it during the beta test phase. The only way to stop it from crashing is reducing the number of lists / filters.
Workaround: instead of adding the list to be filtered on the router, use a DNS that already have the filter applied:
For example:
