Hi, I’ve followed the GL-inet and Astrorelay tutorial step-by-step for the VPN but I am getting a following error when I try to turn on my GL-MT3000 client (latest firmware). Everything was correct until the last point, do you perhaps know why this might fail?
And this is the script ‘gl_block.sh’ file
#!/bin/sh
. /lib/functions.sh
add_block_mac()
local mac_list
ipset flush GL_MAC_BLOCK
config_get mac_list block_mac mac
for i in ${mac_list};do
ipset add GL_MAC_BLOCK "$i"
done
create_ipset_entry()
local exist=$(ipset list GL_MAC_BLOCK 2>/dev/null)
[ -z "$exist" ] && {
ipset create GL_MAC_BLOCK hash:mac 2>/dev/null
add_firewall()
iptables -w -C FORWARD -m set --match-set GL_MAC_BLOCK src -j DROP 2>/dev/null
[ ! "$?" = "0" ] && iptables -w -I FORWARD -m set --match-set GL_MAC_BLOCK src -j DROP
create_ipset_entry
add_firewall
if [ -f /etc/config/gl_block -a ! -e "/etc/config/gl-black_white_list" ];then
config_load gl_block
config_foreach add_block_mac
else
fi
