this is my issue.
I started to notice that the DDNS resolve failed sometimes, so I created a script to ping it every 5 minutes and for example yesterday, it failed twice during the day (I can provide the UTC time in case).
I have a Flint 2 with the Native OpenWrt 24 firmware version 4.6.6-op24.
My questions are:
this could be cause by the Firmware above?
in case where can I found some log in the router?
there is some sort of Gl.Inet global log that can check for outage of their DNS resolution?
Ok, good information, I will check "dig" and write a script for it.
Just to be clear and give the big picture, I first notice this issue not with ping, but because my phone was not able to open a wireguard tunnel with the error that the DNS was not solved.
In the same moment I connected to the router without issue.
The Router was not rebooting or nothing.
there are some log that I can check inside the router that you are aware of? @admon
Not really. The GLDDNS service is the issue, if there is any.
Unfortunately, GLDDNS has not exactly shone with reliability lately due to DDOS attacks, among other things.
