GL.iNet devices and Private Pre-Shared Keys (PPSK)
UniFi devices have the ability to use Private Pre-Shared Keys (PPSK). Is there any way to set up something similar with GL.iNet devices?
I would love this, i had asked for a similar feature request.
Here:
But maybe it now gives more interest given there is a new subnet system and vlans.
Although the limitations seem to be in the mtk sdk for now.
Though I do want to acknowledge here, if someone also tends to want fast roaming enabled a specific patch is needed or clients hop to vlan 1 after a roaming decision.
That discussion is here:
Now that I understand what PPSK is, I don't understand why this isn't being implemented but rather having a Guest and IoT networks. PPSK seems like a much nicer overall solution. @will.qiu, what will it take for your company to implement this?
Thanks for the suggestion. We’ll discuss this with the product team.
Guest and IoT networks offer a straightforward way to keep devices on separate networks, each with its own Wi-Fi name and password. We can also see the appeal of PPSK for doing this under a single Wi-Fi name. Having subnet and VLAN support helps, though assigning devices to those networks by password still requires additional integration and testing across models.
@will.qiu @charles2
Apparently, the idea of PPSK has been brought up before. I'm surprised you guys haven't tried to implement it. I appreciate you and your team taking user feedback and passing it to the wider team. I feel like a PPSK-like solution is a much better quality of life feature for your company's routers. Ubiquiti is limited to WPA2. If GL.iNet can develop a PPSK feature that supports WPA3, it would be a dream come true.
What's the easiest and newbie-friendly method and guide to set up WPA3 Enterprise with the Flint 4?
I'm going off-topic, but again, please make Data Statistics retain a month, 6 months, and a year at the bare minimum. Even better is if this data will be viewable with the GL.iNet account and/or USB storage.
One final thing for now and I have been asking this forever now, but I hope you guys can develop a solution that will fix the ctrld CLI and VPN problem.
The only issue with leveraging wpa3 with ppsk is that you must also define a mac address to the passphrase.
This is by design by wifi alliance which maintains the wpa3 standard.
Their reason is to enhance security, but in practice I see it as a step back because you lose the wildcard ability, and are forced to use a mac whitelist type of setup rather than allow all per phrase which simplifies things like in wpa2.
In my home I use this setup with vanilla OpenWrt but all uses WPA2, with wpa3 and randomized macs by android and apple phones I'm unable to control the macs of 50 devices.
Thanks for the detailed feedback. Here is the current status for each point:
  • PPSK: We have discussed this request with the product team. A proper implementation requires further evaluation, integration, and testing, so we are unlikely to have any updates to share in the near term. We also cannot confirm whether or when it will be implemented.
  • WPA3-Enterprise on Flint 4: The current firmware supports connecting the router to an existing Enterprise Wi-Fi network through Repeater, as described in our EAP guide. It does not currently support configuring the Flint 4’s own SSIDs as WPA3-Enterprise networks. For that use case, you would need to explore a custom OpenWrt and RADIUS configuration; there is currently no supported beginner-friendly setup in the GL.iNet Admin Panel.
  • Data Statistics: We have also included your request for longer retention and storage through a GL.iNet account or USB device in the product discussion. This would require further evaluation, and we cannot confirm an implementation plan or timeline.
  • ctrld and VPN routing: GL.iNet’s domain-based VPN routing relies on DNS results being added to ipset or nftables sets. ctrld does not currently populate these sets, so we do not have a supported router-side solution for this integration. Support for this mechanism would need to be added upstream in ctrld.
Thank you so much! I'm really hoping to see something happen in 2027!
Of all the things that we have discussed, I would say PPSK and Data Statistics make the most sense. Hopefully, this won't be too difficult to implement. I don't think any of your customers want to shorten the lifespan of their internal storage. USB is probably the cheapest way to implement this instead of an online account.
Also, DoH/3 as we have discussed! Please make our dreams come true!
Btw, congrats on the Velica! I hope those nodes will be available separately as Flint 4 owners won't need anything else.
