GL.iNet Flint 2 (GL-MT6000) – MWAN3 Dual WAN Load Balancing Configuration Guide
GL.iNet Flint 2 (GL-MT6000) – Dual WAN Load Balancing Configuration
Hardware
  • Router: GL.iNet Flint 2 (GL-MT6000)
  • Firmware version: 4.8.3
  • OpenWrt-based firmware
  • Installed package:
luci-app-mwan3
Network topology
ISP1 → WAN port
ISP2 → LAN1 port (secondwan)
MWAN3 interface configuration
WAN
  • Enabled: Yes
  • Initial state: Online
  • Internet protocol: IPv4
  • Tracking method: Ping
Tracking addresses:
1.1.1.1
8.8.8.8
208.67.222.222
208.67.220.220
Parameters:
Tracking reliability: 1
Ping count: 1
Ping size: 56
Max TTL: 60
Ping timeout: 2
Ping interval: 3
Failure interval: 3
Recovery interval: 5
Interface down: 3
Interface up: 5
Metric: 1
SECONDWAN
Use exactly the same settings.
The only difference is:
Metric: 2
Members
wan_only
Interface: wan
Metric: 1
Weight: 5
secondwan_only
Interface: secondwan
Metric: 1
Weight: 3
Policies
default_policy
Members:
- wan_only
- secondwan_only
Last resort:
default (use main routing table)
isp1_policy
Members:
- wan_only
Last resort:
isp2_policy
Members:
- secondwan_only
Last resort:
Rules
Devices can be assigned to a specific ISP according to their IP address.
Example 1
Source address: 10.1.1.10/32
Protocol: All
Sticky: No
Policy assigned: isp1_policy
Example 2
Source address: 10.1.1.16/32
Protocol: All
Sticky: No
Policy assigned: isp2_policy
Unassigned devices
Any device that does not have a specific rule automatically uses:
default_policy
Performance results
ISP1
Download: 500 Mbps
Upload: 30 Mbps
ISP2
Download: 300 Mbps
Upload: 300 Mbps
Both ISPs active
Download: 800 Mbps
Upload: 350 Mbps
Notes
This configuration provides:
  • load balancing;
  • automatic failover;
  • traffic separation;
  • continuous link monitoring;
  • device-based routing policies.
This setup uses MWAN3 load balancing and is not based on bonding technologies such as MPTCP, MLPPP, Speedify, or OpenMPTCProuter.
Here is my final config for the OpenWrt Router flash with 4 Wan load balancing, dns hijacking, wan-shaping script as well to adjust for differences in speeds. Readme file is in /etc/config on all the specifics on this configuration.
backup-OpenWrt-2026-10-16-final-shareable.tar.gz (37.3 KB)
