GL.iNet Flint2 Guest WiFi blocked by hidden VPN kill-switch rules - Configuration help needed
Problem Description
The Guest WiFi network on my GL.iNet Flint2 router periodically loses internet access every few hours. This happens automatically without any manual configuration changes or router reboots.
Router Information
  • Model: GL.iNet Flint2 (GL-MT6000)
  • No VPN configured or active
  • AdGuard Home enabled
  • Standard OpenWrt/GL.iNet firmware (4.8.2)
Root Cause Analysis
After investigating via SSH, I discovered the issue is caused by VPN policy blackhole rules that are automatically activated:
ip rule show
# Shows: 9920: from all iif guest blackhole
This blackhole rule blocks all internet traffic from the Guest interface, even though no VPN is configured.
Investigation Results
UCI Configuration Analysis
uci show network | grep vpn_block_guest_leak
Shows:
network.vpn_block_guest_leak=rule
network.vpn_block_guest_leak.gl_vpn_rules='1'
network.vpn_block_guest_leak.priority='9920'
network.vpn_block_guest_leak.action='blackhole'
network.vpn_block_guest_leak.in='guest'
network.vpn_block_guest_leak.disabled='0'  ← Problem: Should be '1'
VPN Script Triggers
The /usr/bin/rtp2.sh script automatically creates these blackhole rules triggered by:
  • Interface status changes
  • Hardware NAT events
  • Firewall reloads
Hardware NAT Connection
The dmesg logs show related MediaTek hardware NAT issues:
Unknown case of dp, iif=b --> ra0
skb_to_hnat_info: callbacks suppressed
Temporary Fix (Works but not permanent)
ip rule del from all iif guest blackhole
This restores Guest WiFi internet access immediately but the rule reappears after several hours.
Attempted Solutions
  1. Router reboot: Problem returns after few hours
  2. Guest network reconfiguration: No effect
  3. Firewall rule analysis: Blackhole rules not visible in standard GUI
  4. LuCI investigation: Policy rules not exposed in web interface
GUI Visibility Issues
The problematic VPN policy rules are not visible or configurable in:
  • Standard GL.iNet web interface
  • Advanced settings
  • LuCI network routing section
  • LuCI firewall rules
This makes the issue impossible to resolve through normal user interfaces.
Help needed!
Please try to execute the following command in SSH:
uci set route_policy.global.enabled="0"
uci commit route_policy
rtp2.sh
This part of the policy route will be deleted after executing above, including blackhole, check if the issue is improved.
But route_policy.global.enabled="0" would disable the entire policy routing system, not just the guest blackhole rule? Security issue?
If the VPN is not configured/not enabled, there is no security issue.
BTW, we have not reproduced the issue you mentioned in my local side.
If possible, please export your configuration backup file and send it to me via PM. I will try to reproduce the issue.
BTW, please let me know the backup's Admin Panel password.
