Hi there,
I’ve got GL.iNet GL-AXT1800 & have configured it as AP mode so i can use it to expand my network & add WiFi too.
Following router manuals I was able to change it to AP mode & it works perfectly with my network setup & wireless clients are able to connect & browse.
Wanted to make use of two additional ports LAN1 & LAN2 to add my TV & SAT Box, here what Ive started to have issues with it …
ATX1800 wasn’t flashed or updated when i received as i wanted to test it out b4 i head on with it.
LAN1 interface was working properly
LAN2 wasn’t at all, checked logs & saw eth1 briefly up & connected as 10mbt, then it went off!
I’ve decided to flash it with latest beta to see if that would solve, it didn’t.
Checking (br-lan) noticed that both eth1 & eth2 both shared same MAC, went ahead & changed eth2 to a different number (last octate) & my TV got an IP & started working.
Sat-box didn’t work at all no matter what MAC address i assign to it from interface, changing out cables between devices, renders the same result one device is on other is not.
Which confirms that cables/devices are working, ATX1800 ports aren’t.
all of above was done with (power cycle) to each change made.
Any help would be great, i hope this not a defected item.
Thank you
