I am trying to get USB tethering to work
1.USB tethering on GL.iNet GL-AXT1800.
Once “USB tethering” connects and has IP ADDRESS . I try to connect one of the GL-AXT1800 Lan ports to TPlink mr600v2 sim router WAN port. The TPlink mr600v2 Wan port will not pickup the connection when I try to connect in the web admin section. (image 2 tplink STATUS will say “DISCONNECTED” greyed out table)
2.Ethernet Tethering If i use my S21FE5G phone and Ethernet tether to the GL.iNet GL-AXT1800 and get a Ethernet connection established and do the same thing so ( GL-AXT1800 Lan port to TPlink mr600v2 sim router WAN port) connection is established WORKS fine.
Q) How do I get USB tethering to work, Is this do to with manually setting ip addresses?
images of working (2)Ethernet connection below
STATUS “CONNECTED” greyed out table
